First post, by Red_88
Hello,
Since I have some games which use DOS/4GW and reading the manuals of these games some question are coming up.
For example I have a game called Fast Attack, the manual states only that it needs at least 528kb of free conventional memory and at least 8mb of RAM. The manual does not mention XMS/EMS. I have read DOS Extenders actually can manage memory by themselves. The game runs with dosbox settings XMS=false, EMS=false. Question is if it is recommend doing it this way or should I change my settings.
In Silent Hunter the manual states it needs: 8mb of ram, minimum 500,000 bytes of free conventional and 6,900,000 bytes of free XMS.
Both games use DOS/4GW (Silent Hunter doesn't show the DOS/4GW banner. But I checked the .exe for it with the bind utility from DOS32A).
Another (but older example) I have is AEGIS:Guardian of the fleet, it uses DOS/4GW 1.8 and also requires XMS or EMS memory.
How come different games which all use DOS/4GW are different of the requirement of XMS memory?
