Crystal FM disable
First post, by Marmes
Hello!
Does anyone knows how to disable internal FM on Crystal CS4236/7/8/9 inside windows 98, so I can use an external OPL3 synth?
I can do it with debug, but after opening another software it turns back to normal internal FM, it seems that windows totally ignores eeprom.
Thanks!
Reply 2 of 6, by appiah4
Tiido wrote:
You probably need to patch the Crystal driver so it wouldn't intercept FM stuff...
Is this even possible? Don't FM Synths respond to address 388h regardless of drivers?
Reply 3 of 6, by Tiido
In Windows everything changes, a driver can trap any IO port and do whatever it wants with it before the hardware actually gets to see any action, if at all.
The current problem is likely driver doing full init to how it sees fit, ignoring any hardware configuration that EEPROM dictates. If you're lucky there may be some registry key that can be used but it will all be completely driver specific if such a thing exists at all...
Reply 4 of 6, by Marmes
There might be an option in registry 😀 will try later.
Reply 5 of 6, by Marmes
Driver needs to be patched
Reply 6 of 6, by appiah4
Maybe the mixer can mute the FM Synth instead?
