First post, by greg2002
I can't seem to get my Sound Blaster 16 to work on my IBM AT 286. Any suggestions ?
Reply 1 of 10, by gdjacobs
What model? Is it a PnP card or is it jumpered?
Reply 2 of 10, by greg2002
Yes, it's PNP, and says 386 required, but I don't see why. My Sound Blaster Pro 2 works fine, and the Sound Blaster 16 is only the next generation. I need it to run in DOS.
Reply 3 of 10, by Joseph_Joestar
Could be a Plug and Play issue. Early implementations of PnP were flaky at times.
That said, you wouldn't get much benefit from using a SB16 instead of a SB Pro on that machine. Only late-era DOS games supported 16-bit sound samples and it's unlikely that they would run well (if at all) on a 286.
My retro builds
Reply 4 of 10, by derSammler
What did you do so far and what does not work?
Does CTCM find the card at all? (that's Creative's mini PnP manager)
Reply 5 of 10, by jesolo
Also run CTCU to check your PnP card's configuration.
You also need to check that you don't have other devices that conflicts with the DMA & IRQ settings of your card. What other devices do you installed?
Reply 6 of 10, by matze79
Creative Tools require 386 CPU,
but you could use CT4170.EXE instead or Intel ICU
Intel ICU
ftp://ftp.dosreloaded.de/Plug&Play/Intel%20ICU/
CT4170:
ftp://ftp.dosreloaded.de/Soundkarten/Creative … 6%20PNP%20Tool/
or you can combine CTCM with EMU386. ( With many limitations.. )
http://survpc.tripod.com/emu386/
Reply 7 of 10, by greg2002
Thanks guys !!!! I will try tomorrow to get it working, using all of your ideas. I use a SB Pro (CT1600) in one of my ATs and it works fine. I went with the SB 16 because it was so much cheaper than a Pro and it was brand new, unopened, with manual and installation disk.
Reply 9 of 10, by greg2002
Success !!! I changed the motherboard (to go from 6 to 8 MHz) in my AT, so I added the Sound Blaster 16 card right after the disk controller, HardCard, and video cards (and also a temporary 128MB memory board so Install would run) and I now have SOUND !! Must have been an IRQ conflict with the SCSI controller. I will install that and the CD player tomorrow and then play some music !!
Thanks for the help !!
Reply 10 of 10, by greg2002
I did have an I/O address issue with the Adaptec 1505 scsi card and Hardcard XL, so I had to install the NEC scsi card because it let me change the address. The Adaptec has only 1 jumper so you get to choose one of 2 addresses, but they both caused issues. Anyway, now running CDs with sound !!
