First post, by GabrielKnight123
When playing games through an MT32 is the output stereo, Im not really asking about the combined left and right channel to make stereo but rather do games use stereo with the MT32 so that some instruments go to the left and some to the right or are they all sent the same way to both left/right to get "stereo". I need to know because I have a modded MT32 1st gen and it took me a while to figure out how to get reverb to work which is not through the normal outputs. I have one reverb output from the MT32 going into a stereo mixers mono input and one dry output from the MT32 going to the mixer as well to another mono input, so I'm using "left" reverb and "right" dry on separate channels so I can mix them independently and I'm using mono for the mixer or I would have double the amount of dials to change one thing, that's why I need to know if games send some music to the left or right otherwise I might be missing some music "effect" by using only one channel each from reverb and dry as there are four outputs for reverb and dry on the modded MT32. I hope that wasn't to hard to understand.
