First post, by evgs
Hi, vogons.
Chaintech 6VIA5T-D100A is a very good mainboard for building retro-machine (support Tualatin, AGP4x, and have ISA for old sounblaster-compatible soundcards)
But it have an issue, and this info may be interesting:
6VIA5T-D100A doesn't recognize SB AWE64 (CT4520)
I've tried to set IRQ/DMA manually in BIOS, tried different BIOS versions too.
I've tried 2 same motherboards and 2 soundcards but nothing helped.
People on the forum wrote they tried to flash different bios from
other motherboards (gigabyte GA-6VTXE, acorp 6VIA85T) based on same chipset and it helped. AWE64 was detected, but other bugs appeared.
Root of the problem here:
https://www.phantom.sannata.org/viewtopic.php … =499034#p499034
This mainboard doesn't have working 14MHz on ISA
This is BIOS bug, it doesn't sent 14MHz to ISA
and here is hardware fix:
resistor is 100-220 Ohm.
need to cut trace 2:
    103.36 KiB
    412.22 KiB
    92.35 KiB
Reply 1 of 1, by Tiido
I originally did the mod to get CMI8330 based cards to work which also rely on 14MHz being present on the ISA slot, that's when I discovered that the signal was not oscillating. Luckily the second PLL output could be used to fix the issue.
