First post, by Robin4
- l33t
Hello,
I want to give you guys a tip how to make a purchase on the website from Soleau software.. This is how in looks in 2019:
http://www.soleau.com/dosgame.html (what url / link you are clicking on the purchase is always ANT RUN.
Today in 2019 i wanted to purchase the registered version of bolo ball..
Some of the links in the dos games section are death today. When you try to purchase it, you will ended up with a purchase page for ANT RUN.. always on each game you are trying to buy.
Its very annoying when this will happend. First i made a purchase for the game called: Blockman 1 to see if when i spend some cash that it would return with a registering key.
And yes that will happend few minutes later when it arrived in my mail box. Tried it out on the shareware version which became a registered version on my name.
So the first attempt succeded, happy when the automatic registering service still would work by now in 2019!..
A also wanted to purchase bolo ball.. But it wont work..
So i used the `waybackmachine` and ended up on this website:
http://web.archive.org/web/20150422020917/htt … es=1&showcart=1
When you now click on buy now you should getting and error..
The trick is to copy and paste the url that connected to the purchase section on a new tab in your browser. Ending up on the purchase section.. Check / validate if every section of the form is filled in alright..
Then make the purchase with paypal.. After 2 or 3 minutes your are getting the registration information by e-mail. The instuction are in the e-mail for how the register your game.
After the registering is done, you got the full version.
URL to ANT RUN DOS:
https://secure.shareit.com/shareit/checkout.h … 1143&quickbuy=1
Alpha man dos:
https://secure.shareit.com/shareit/checkout.h … 1064&quickbuy=1
Balloon Challange dos:
https://secure.shareit.com/shareit/checkout.h … 1144&quickbuy=1
Blind wars dos:
https://secure.shareit.com/shareit/checkout.h … 1145&quickbuy=1
Blockman 1 dos:
https://secure.shareit.com/shareit/checkout.h … 1146&quickbuy=1
Blockman 2 dos:
https://secure.shareit.com/shareit/checkout.h … 1164&quickbuy=1
Bolo adventures 1 dos:
https://secure.shareit.com/shareit/checkout.h … 1167&quickbuy=1
Bolo adventures III dos:
https://secure.shareit.com/shareit/checkout.h … 1168&quickbuy=1
Bolo ball dos:
https://secure.shareit.com/shareit/checkout.h … 1169&quickbuy=1
Crusher 1 dos:
https://secure.shareit.com/shareit/checkout.h … 1173&quickbuy=1
Crusher castle 2 dos:
https://secure.shareit.com/shareit/checkout.h … 1174&quickbuy=1
Dotso dos:
https://secure.shareit.com/shareit/checkout.h … 1291&quickbuy=1
Facetrex dos:
https://secure.shareit.com/shareit/checkout.h … 1296&quickbuy=1
Isle wars dos:
https://secure.shareit.com/shareit/checkout.h … 1298&quickbuy=1
Ladder man III dos:
https://secure.shareit.com/shareit/checkout.h … 1300&quickbuy=1
Loader larry dos:
https://secure.shareit.com/shareit/checkout.h … 1301&quickbuy=1
Mice maze dos:
https://secure.shareit.com/shareit/checkout.h … 1302&quickbuy=1
Mice men dos:
https://secure.shareit.com/shareit/checkout.h … 1303&quickbuy=1
Mice moves dos:
https://secure.shareit.com/shareit/checkout.h … 1308&quickbuy=1
Numlo dos:
https://secure.shareit.com/shareit/checkout.h … 1312&quickbuy=1
Oilcap dos:
https://secure.shareit.com/shareit/checkout.h … 1313&quickbuy=1
Plix dos:
https://secure.shareit.com/shareit/checkout.h … 1314&quickbuy=1
Quato dos:
https://secure.shareit.com/shareit/checkout.h … 1315&quickbuy=1
Raku master dos:
https://secure.shareit.com/shareit/checkout.h … 1316&quickbuy=1
Robix dos:
https://secure.shareit.com/shareit/checkout.h … 1317&quickbuy=1
Rockman dos:
https://secure.shareit.com/shareit/checkout.h … 1318&quickbuy=1
Sea run dos:
https://secure.shareit.com/shareit/checkout.h … 1319&quickbuy=1
Spider run dos:
https://secure.shareit.com/shareit/checkout.h … 1320&quickbuy=1
Squarex dos:
https://secure.shareit.com/shareit/checkout.h … 1321&quickbuy=1
Taxi run dos:
https://secure.shareit.com/shareit/checkout.h … 1322&quickbuy=1
Wall pipe dos:
https://secure.shareit.com/shareit/checkout.h … 1323&quickbuy=1
Wordle dos:
https://secure.shareit.com/shareit/checkout.h … 1324&quickbuy=1
Wordmax dos:
https://secure.shareit.com/shareit/checkout.h … 1325&quickbuy=1
General requirements: This is an 8 bit DOS game which will not run on some versions of XP. It WILL NOT run newer computers using Windows Vista or Later. DO NOT order this game unless you know it will run on your computer.
