First post, by red_avatar
The title is pretty clear - I can't get Leisure Suit Larry 3 to work with my MT-32 no matter what. This on a Pentium 75 so not even that fast a machine. I have disabled cache to a level where the machine is VERY slow (286 speed perhaps) but still no go. I can't seem to find any "patched" DRV files for MT32 either. GOSIERRA can't patch the DRV so that's a dead end as well.
With Space Quest 3 I had similar problems but I found a combo of Soundblaster and MT-32 into a single DRV file and that fixed it.
Would anyone have any idea on how to make this work?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 9, by jesolo
These older Sierra games required an intelligent (real) mode MPU-401 MIDI interface. If you don't have one, then you can use SoftMPU.
Reply 2 of 9, by red_avatar
jesolo wrote on 2019-12-28, 07:39:
SoftMPU is not the solution - I have that installed by default to prevent buffer overflows but my Sound Blaster has a pretty good MPU-401 interface so I haven't really needed it for anything else - most games work fine with MT-32 and those that don't, won't work with SoftMPU except for the buffer overflow error.
Also: I can play all other Sierra games I tried just fine although some needed patched files. There's something odd with LSL3...
Retro game fanatic.
Reply 3 of 9, by jesolo
Actually, it's because you had SoftMPU installed that you haven't had any issues with your other Sierra games, particularly the older titles that supported the MT-32 (before the General MIDI days). No sound card has an intelligent (real) mode MPU-401 MIDI interface. SoftMPU emulates an intelligent (real) mode MIDI interface to enable you to play games that requires it.
I know that some of those games didn't want to run properly if your sound card's IRQ wasn't set at IRQ7 (I had that issue with my SQ3 version). Also make sure that you have the sound card environment variable (the SET BLASTER environment variable) set correctly in your Autoexec.bat file.
Apart from your CPU, what other hardware do you have installed? What operating system?
Reply 4 of 9, by red_avatar
I may not have been very clear in my previous post: SoftMPU doesn't fix any games that don't work that I tried, except for buffer overflow ones. I only load SoftMPU by default on my standard boot - for testing games I have a special boot order without SoftMPU since I like to know which games require extra actions.
My Soundblaster is set at IRQ 5 but LSL3 doesn't use sound effects so shouldn't be an issue.
More info: it's a HP Vectra VE 5/75, 16MB of RAM, DOS 6.22 - all pretty standard for a higher-end PC of 1995.
Sound cards: Soundblaster 16 CT2940 (220-5-1-5) (chosen for very good sound quality, no noise - OPL3 model too) + Aztech Multi Media Pro 16V (chosen for very good MPU-401 interface without hanging notes). Aztech MIDI port is set to 330 since this is the default port many games look for. Only the MIDI port is activated to avoid more IRQs being used.
Before this, I used a Soundblaster CT2230 which had the exact same problem with LSL3. I didn't have the hanging note bug there in MIDI, but certain games had a lot of clicking. This was the main reason I changed the setup.
I also have another card on the way since I'd prefer to move back to a single card: the Yamaha Audician 32 Plus which from what I hear, is pretty much the ideal card to have. I'm also interested in getting this card now that I got both a MT-32 and a SC-55:
https://www.youtube.com/watch?v=ymQJvwOTM0E
Retro game fanatic.
Reply 5 of 9, by red_avatar
OK I found the solution for my headaches. It's rather simple: the second soundcard received port 330, the first soundcard got port 320 BUT CTCM would replace the SET BLASTER settings behind my back in autoexec.bat. Manually setting 330 after boot up fixed it.
Retro game fanatic.
Reply 6 of 9, by gdjacobs
jesolo wrote on 2019-12-28, 09:59:
The only sound card that does is the Orpheus that Keropi is making.
Reply 7 of 9, by derSammler
So the Roland LAPC-I is no sound card then?
There were thousands of sound cards made, with some like the Innovation SSI-2001 forgotten for decades and only rediscovered a few years ago. Stating that no sound card has an intelligent mode MPU-401 interface is therefore quite overbearing.
Reply 8 of 9, by gdjacobs
derSammler wrote on 2019-12-29, 09:10:
As all audio is piped over the MPU-401 interface, I consider it a MIDI interface and synthesizer, just like the IMFC. Both were meant to be used static or at most preloaded with custom samples. Most of what I consider as PC sound cards were meant to be driven dynamically by the CPU.
Point taken, although such a card (should it appear) would be an interesting unicorn indeed.
Reply 9 of 9, by jesolo
gdjacobs wrote on 2019-12-29, 10:48:
As all audio is piped over the MPU-401 interface, I consider it a MIDI interface and synthesizer, just like the IMFC. Both were […]
Basically what gdjacobs stated is what I referring to. Your standard Sound Blaster/Adlib compatible PC sound card.
The Innovation SSI-2001 is quite an interesting card, but it still didn't have any MIDI interface (based on what I can see).
