First post, by gargamel9
Hi there.
Im running Star Wars Rebellion on steam win 10 64bit
Space battles seems to work ok with dgvoodoo logo and all but when you zoom in the ships models they are rendered quite poorly. Like with the lowest settings of the games of the time.
They look like lego blocks and the colors are like CGA.
In the original game the ships models looked way better and I cheked the settings and are at high quality.
Anyone knows what might be happening?
thx
Reply 1 of 2, by ZellSF
1) You should probably write down steps to get to a scene showcasing the issue as quickly as possible. I considered downloading this to check this out, but I remember this game, it doesn't really jump anywhere near directly into a battle scene and figuring out how to get into one requires some effort.
2) You should probably post screenshots of what is correct behavior, and what is wrong behavior. "In the original game" makes it sound like you're working from your memory which isn't always accurate.
3) Try different card types in dgVoodooCpl and try setting a lower VRAM size, the game might not see higher VRAM sizes and think it doesn't have enough VRAM for better graphics.
Reply 2 of 2, by Dege
Yes, could you attach a screenshot plz?
