First post, by GabrielKnight123
Hi everyone, I've built a 486 pc using a Pro Audio Spectrum 16 but when I use the full speed of the CPU at 66Mhz the audio is very scratchy but using the turbo button to slow the pc down it sounds fine and clear, if I change the AT bus clock from CLK/4 to CLK/5 I get clear sound at 66Mhz is this safe to run the ISA clock at CLK/5 for the PAS16 and if it is is it also safe for a MPU-IPC-T card.
