First post, by kruwi
So I think I have discovered a small but slightly annoying bug.
In Police Quest 2 the the keyboard is often annoyingly laggy. Sometimes you can type in characters and they will only show up after about 1-2 seconds. The mouse pointer also seems to be a little "nervous" at times, flickering a little bit. The game is still playable, but especially the keyboard behaviour is really annoying. Happens with both 0.74-3 and the newest clean svn builds which I normally prefer over the official 0.74-3 version. Using the standard config difn't change anything. Lowering the cycles to about 1000 or any other value didn't change anything, too.
My system: Windows 10 64 bit, 4 GB of RAM, Pentium N 5000 CPU.
It also happens in my dosbox-installed Ms DOS 6.22 environment using a hardfile image.
ScummVM runs the game without any annoying keyboard behaviour.
Visit the end of the internet: www.groskreutz.de
