First post, by Kahenraz
I've only ever experienced this smell from a small handful of devices so far (all laptops) but it is always the same strong, distinct odor; almost like vinegar.
When removing the drive from one of the older laptops I've been using (a Dell Inspiron 5100), I noticed that it had begun to emit the stink. It is definitely coming from the inside of the device as it is much stronger when I put my nose close to it. For this laptop, the smell is strongest in the hard drive bay and not any of the exhaust vents as one might expect.
Is anyone familiar with this stink or have any insight on the subject?
Reply 1 of 17, by cyclone3d
Maybe the adhesives from the different insulation tapes used?
The clear-ish yelllow-ish tape tends to smell when it is peeled back.
Sure you don't have a rodent or cat peeing on your laptop?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 17, by texterted
It's the "magic smoke" waiting to come out!
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 3 of 17, by SirNickity
The only two smells I associate with electronics are the kinda nice one that new electronics have, that sometimes you will still get when pulling a fairly NOS-ish motherboard from its anti-static bag; and the unfortunate coating of funk that indicates this particular new eBay score came from a humid locale and has been hanging out in a basement or garage for many years. Soon to be accompanied by the smell of dish soap.
Reply 4 of 17, by DNSDies
I think it's the conformal coating breaking down over time into its constituent parts.
Reply 5 of 17, by brostenen
If stuff is stinking from within computers, then the smell might be that "fish" smell, that leaking electrolyt caps are producing.
Reply 6 of 17, by jaZz_KCS
You are describing a different, yet quite similar smell that I am quite versed with that is emitted by new or NOS power supplies.
Reply 7 of 17, by schmatzler
There are so many smells on old electronics that are hard to describe.
I like that 70s smell. I always associate it with leaded solder and a specific type of ancient flux used to bring everything together, but that's probably just my imagination. It's a pleasant kind of smell, tough.
DNSDies wrote on 2020-01-14, 19:21:
I think so too, and that's one of the negative kind of smells. I have a radio from 1978 with a few boards inside. The coating on the boards turned into some kind of brown, glue-like substance and it stuck to everything. The smell was really bad, when I cleaned them I thought I was cutting onions.
Then there's that "maritime" smell, like rotten fish, which is most likely due to leaking caps.
The "new car smell" I mostly associate with modern electronics, even slightly used devices still emit that smell. Maybe it's created by the modern process of making plastics?
Edit: There's also ozone smell, from (bad?) power supplies.
Reply 8 of 17, by ifrit05
One of my favorite smells are new (to me) vintage hardware being opened before cleaning. That and freshly printed laser printer paper. Yeah, weird, I know.
P3B-F v1.03 | VIA C3 Nehemiah 1.0A @ 500/66 | 128 PC133 | GeForce 256 SDR | PicoGUS+Yamaha OPL3-SAx | FreeDOS 1.3
Reply 9 of 17, by retardware
The old flame retardants' smell is so lovely (at least for a moment).
On the other hand, I really hate the smell of pre-1982 big electrolytics, sort of chemical foul smell, similar to polychlorinated biphenyls' sweetness.
Almost extinct nowadays is the spicy smell of ancient tube electronics which the hot stuff emanates while autolysing the dust 🙁
Reply 10 of 17, by bristlehog
I experienced the smell many times when buying old PCs. When I clean them thoroughly, including washing everything (that has no batteries and moving parts), the smell goes away.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 11 of 17, by SpectriaForce
I have noticed over the years that old CRT monitors and televisions emit a distinctive smell when powered on.
Reply 12 of 17, by Ultrax
I've definitely noticed old laptops tend to have a smell similar to that of either crayons, BO, or as OP mentioned, vinegar. I'd assume the cause is due to adhesives becoming older, but that's just a guess. You aren't alone though - I've definitely experienced this too.
Ultrax
__
Presario 425|DX2-50|8MB|SB V16S|D622/WFW3.11 😎
Deskpro XE 450|DX2-50|32 MB|NT4.0/95
SR2038X|Athlon 64 X2 3800|2G|GT710 WINXP
Dimension 4400|P4 NW 2 GHz|256M|R128U AGP|WINXP
HPMini311|N270|2G|9400M|WINXP
Libretto50CT|P75|16MB|YMF711|WIN95 😎
Reply 13 of 17, by brostenen
SpectriaForce wrote on 2020-02-01, 21:37:
Ahhh.... The smell of childhood evenings, in front of the tv while watching movies.
Reply 14 of 17, by imi
the smell of roasting dust ^^
Reply 15 of 17, by kolmio
My 486 didn't smell anything. That's good. But it didn't get hot, just warm.
On the other hand, my Slot 1 machine smells with some chemicals when it gets hot and I don't like it at all. No other computer I had never smelt, so now I even think of replacing it with something else.
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 16 of 17, by Intel486dx33
Back in the 1990’s my Pentium based computers use to smell
Smell like burnt PCB
I think they ran hot.
I think it was the New motherboards being burnt in from running hot.
The Stench of electronics.
Smells toxic I had to empty my house of computers
I noticed this smell in computer classrooms too.
Reply 17 of 17, by Errius
Yes, I keep my computers in cupboards (repurposed wardrobes) and there is a strong smell when I open the doors.
I assume it's the smell of leaking capacitors...
Is this too much voodoo?
