First post, by stalk3r
I would need the jumper settings for this one, but could not find any ID or model number on it.
It is an UMC 386 motherboard with MR BIOS. Thanks
Reply 1 of 4, by Cyrix200+
What's the version of the MR BIOS? We might want it here: How about a MR-BIOS ROM file repository?
Edit: can't help you wiith the board sorry, but it looks like a common design.
1982 to 2001
Reply 3 of 4, by computerguy08
You have many possibilities to make a BIOS dump.
One way would be to get a TL866II programmer (or similar) and use that to dump it.
If you don't want to waste $60+ on a programmer, you can do the same thing with an Arduino Mega, some wires and a bit of code.
All of the above doesn't involve the use of a motherboard or other expansion cards.
