First post, by Guybrush3pwood
I know Voodoo 1 is a natural choice, but lets say for the moment that I don't want to spend $100 on a video card, what's the best video setup for a system from 1996 with a 133mhz Pentium processor running Windows 95? I've got PCI and ISA slots to work with. Thanks!
Reply 1 of 20, by The Serpent Rider
Voodoo 1 is not a video card.
Reply 2 of 20, by Guybrush3pwood
3D graphics card, whatever you want to call it. Happy now, comic book guy? I think people get what it is I'm asking.
Reply 3 of 20, by The Serpent Rider
Riva 128, Riva TNT/TNT2, GeForce 2 MX, S3 Savage 4.
Reply 4 of 20, by clueless1
If you want to be strict about the year, then your options are:
ATI Rage II
Matrox Mystique
Tseng ET6000
Riva128 is from 1997.
Reply 5 of 20, by Shagittarius
Voodoo 1 & 2 require a primary video board is what he was saying. So by saying "A voodoo 1 is an obvious choice" you haven't specified what video card you are going to use because a voodoo 1 and 2 do not work without a primary video card. Just making sure this is clear. I wouldn't want to see anyone spend that money and think the card is broken.
Personally I wouldn't bother with any 3d acceleration for a 133Mhz system. Pick any decent PCI card like an S3 or a Diamond Stealth and you should be good.
Reply 6 of 20, by jaZz_KCS
A 133 Mhz Pentium system would be best paired with a 2D card of the same irk/era. Trio64V+ would be a good fit, as well as the aforementioned Rage II, Mystique and Tseng. A 3D accelerator in the veins of Voodoo1 is feasible, albeit highly optional. If you want 3D acceleration, then go for it, but your machine is thoroughly at home in the software rendering department, in the times before 3D acceleration took off, spec- and era-wise.
Reply 7 of 20, by maxtherabbit
there's always the dookie old s3 virge
it's a meme card for 3d but it does just fine in DOS
Reply 8 of 20, by jaZz_KCS
maxtherabbit wrote on 2020-01-18, 21:40:
That is because it is a Trio64V+ (with weird 3D, which looks and feels - although nice to experience - basically like alpha Direct3D (missing stuff and very low FPS))
"It's 3D aight, but not...... accelerated."
Reply 9 of 20, by Cobra42898
id go for a ati rage pro PCI in a system like that. it would be roughly period correct and decent performance for the age.
Searching for Epson Actiontower 3000 486 PC.
Reply 10 of 20, by Skanque
There is also NEC PCX1 if you want to be exotic and try something different than 3dfx and still be a pure 1996 machine.
Reply 11 of 20, by GigAHerZ
clueless1 wrote on 2020-01-18, 21:29:
If you want to be strict about the year, then your options are: ATI Rage II Matrox Mystique Tseng ET6000 […]
ATI Rage II
Matrox Mystique
Tseng ET6000
Doesn't Ati Rage Pro Turbo also fit "under-1997"?
I'm running that on my P225MMX. 😀
A little about software engineering: https://byteaether.github.io/
Reply 12 of 20, by BinaryDemon
Rendition Vérité V100o would be a 1996 option as well but those are as tough to find and cost as much as Voodoo 1’s.
Reply 13 of 20, by Guybrush3pwood
Shagittarius wrote on 2020-01-18, 21:34:
No worries. I do understand the difference, I was just asking for something other than the usual Voodoo 1 + random PCI video card combo you see suggested a lot.
Funnily enough, I ended up going for a Voodoo 1 + Matrox Millennium combo anyway, but I appreciate everyone helping me explore alternative options anyway!
Also, for everyone who suggested Trio64V+. The system actually has that onboard!
Reply 14 of 20, by clueless1
The Trio has fewer compatibility issues (at least in DOS) than the Millennium. But the Millenium is a great Win9x card. Enjoy!
Reply 15 of 20, by Guybrush3pwood
clueless1 wrote on 2020-01-25, 23:15:
Yeah? What would you do? Just install the voodoo and go through the onboard video or use the separate Matrox card?
Reply 16 of 20, by clueless1
Guybrush3pwood wrote on 2020-01-25, 23:59:
Depends. If you're doing more in Win9x, go with the Matrox. If you're mostly in DOS, go with the onboard S3.
Reply 17 of 20, by Guybrush3pwood
clueless1 wrote on 2020-01-26, 00:03:
Sounds like a plan, thanks!
Reply 18 of 20, by candle_86
Well shoot I was going to say you could go with the forgotten nv1 from Nvidia, it even has a Sega Saturn gameport.
Reply 19 of 20, by The Serpent Rider
It's barely useful.
