First post, by d3lmund0
Hi all!
I just bought a Roland Sound Canvas SC-88VL and hooked it up by using the gameport of my Sound Blaster Live. I'm running WIndows 98 and set the midi output to ''SB Live! MIDI OUT''
If i play a .mid file, the Roland works perfectly and shows the instrument bars correctly. If i run games however the Roland doesnt picks up any signs of midi imput.
Do i have to set the Sound Canvas in a different mode or something ? Or maby change a setting on the pc ?
Please help 😀
Greetz
Reply 1 of 10, by CrossBow777
What game or games have you specifically tried to test it with? And are you running the games from Windows 98 or MSDOS?
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 2 of 10, by d3lmund0
I tested doom and duke nukem 3d. Here i can set the sound canvas as default but the SC isn’t receiving midi signals. I also tried Monkey Island 3. Again no midi, but normal sound
Reply 3 of 10, by CrossBow777
What is controlling the SC-88? Are you using a gameport to MIDI cable from the sound blaster?
Reply 4 of 10, by d3lmund0
Yes. I connected the gameport to the midi-in and routed back the audio through line in.
I read something about softMPU, do i need that?
Reply 6 of 10, by cyclone3d
kixs wrote on 2020-01-28, 17:20:
Yes, you do need to run SoftMPU before the game.
Why do you need softmpu? The module is an SC-88VL, not an MT-32 so it doesn't need intelligent mode.
See here for some instructions:
https://www.ixbt.com/multimedia/sblive-dos.shtml
I think it should work under DOS just fine if configured properly.
I'll have to test it out when I get a chance.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 10, by d3lmund0
Thanks. Do you know an instruction site that isnt russian ?
Reply 8 of 10, by cyclone3d
Use google translate. Pretty readable with it translated.
When I get a chance to test, I'll make my own instructions and post them on vogons. That Russian page seems really, really wordy compared to what it could be.
YMF7x4 Guide
Reply 9 of 10, by kixs
cyclone3d wrote on 2020-01-28, 18:02:
Why do you need softmpu? The module is an SC-88VL, not an MT-32 so it doesn't need intelligent mode. […]
My bad 🙁
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 10 of 10, by Kamerat
d3lmund0 wrote on 2020-01-27, 20:47:
You might be able to use the gameport for MIDI if you use the WDM drivers instead of the VxD ones. Windows will then emulate MPU-401 and Sound Blaster Pro by itself. One other option are using VDMSound for MPU-401 emulation and disable the Sound Blaster emulation part. Many other "non Creative" PCI sound cards of that period got proper MPU-401 UART support.
YouTube channel
