First post, by Cga.8086
Hi folks.
this is part of my retro motherboard collection. These motherboards are some of my most precious ones. Some of you might remember them or any of them.
I come here to beg for your help since i am looking for the Driver Disc for each. Maybe you have any of these around and want to help me sharing an image.
this is the list of motherboards i am missing the disc:
FIC PA-2013
AOPEN AX59 PRO
GIGABYTE GA-5ax
GIGABYTE GA-BX2000+
GIGABYTE GA-6VTX
ASUS P3B-F
Epox MVP3G2
MSI KT7 TURBO2
Reply 1 of 21, by Horun
Cga.8086 wrote on 2020-02-01, 01:34:
MSI KT7 TURBO2
That is a MSI Via Apollo KT133A board, same as MSI K7T Pro, K7TM Pro, MSI MS-6330, and a few others. Any of the driver disks for those would be same as Turbo2 disk and will most likely look just a standard MSI disk like the picture attached. If you could do some research you will find the inner ring stamp has a number (like Asus driver cd's have on the label) that relates to the Kt133A boards. Added: the Asus P3B-F used two diff driver cd's, one was numbered M114, Support CD rev 4.26 1999 and seen in the pic below. The other was a diff M number is Rev 4.29 and found here: https://archive.org/details/3135521376_qq_P3B
Reply 2 of 21, by Cga.8086
Horun wrote on 2020-02-01, 01:53:
MSI KT7 TURBO2
Oh my god, it is so nice to see the box of that asus
Y2k ready hhahahahah
Reply 4 of 21, by Horun
Tommaso72 wrote on 2020-02-01, 07:51:
Unfortunately the only one I have is the ASUS P4P-800 LE. I will look around regardless.
You have the driver CD for a P4p-800 ? What is the M number of it please ?
Reply 8 of 21, by PC Hoarder Patrol
This is a list of what I have in terms of original motherboard CDs if anyone sees anything they'd like or would like more info on
Abit KV-85 V2
Abit SA6R
Asrock 960GC-GS FX
Asrock 985GM-GS3 FX
Asrock K7S41GX
Asrock K8N68PV-GLAN
Asrock N68C-GS FX
Asrock P4I65G
Asrock P4I945GC
Asus M5A78L-M/USB3
Asus P5B-VM
Asus P5Q-VM DO
Biostar 945GC-M4
Biostar G31-M4
Biostar G41D3+
Biostar G41U3G
Biostar P4M900M4
Chaintech 7NJS ZENITH
DFI P45 LP JR
FIC VA503+
Gigabyte 686BLX
Gigabyte 6BA
Gigabyte 78LMT-USB3
Gigabyte 8IPE1000MK
Gigabyte G33M-DS2R
Gigabyte MA78GM-S2H
Intel SDS2
Jetway 530BF
Jetway 913AF(Skt 370 / Slot 1)
Jetway JNC84E-LF
MSI 760GMA P34 FX
MSI 760GM-P23 (FX)
PC Chips M825G
Soyo KT333 DRAGON Platinum
Winfast 760GXK8MC
Winfast K7S41M01C
List
Reply 9 of 21, by Cga.8086
DenizOezmen wrote on 2020-06-05, 12:02:
GIGABYTE GA-BX2000+
I do have a CD for this board here (labelled GA-IUCD_14). Should it still be needed, let me know.
HI Deniz
please
please
plase share that cd iso for GIGABYTE GA-BX2000+
you can use mediafire, zippyshare, anything you like
Reply 10 of 21, by Horun
Tommaso72 wrote on 2020-06-05, 06:42:
Sorry to message you back so late, have not been here in a while. I do have the CD in my collection, if you still need it let me know.
Tommaso
Yes would like it. If you have the original CD can you look at it and find the Asus part number, should be a M xxx in big print, usually on the left side of the CD like this:
https://archive.org/details/asusm166cuv4xa7va7m
Take a picture of the CD and Image it, send both to where every you can. Thanks
Reply 11 of 21, by Horun
PC Hoarder Patrol wrote on 2020-06-05, 17:25:
Gigabyte 8IPE1000MK
Think that cd was also used for the 8iPE1000-G and a few other 8iPE boards, would be nice to have that one !
Reply 12 of 21, by debs3759
Gigabyte MA78GM-S2H
Jetway 530BF
I have these two boards. I have all the drivers, but would love original CD images, if you don't mind posting them.
Reply 14 of 21, by Horun
DenizOezmen wrote on 2020-06-06, 06:53:
Thanks ! Looks like it covers most of the Intel 430, 440, 810, 815 and 820 chipset based boards.
Reply 15 of 21, by Cga.8086
thank you so much!
i am in luck, so far i was able to get CDs for these boards
FIC PA-2013
ASUS P3B-F
GIGABYTE GA-BX2000+
Still looking for drivers CD images of these boards:
AOPEN AX59 PRO
GIGABYTE GA-5ax
GIGABYTE GA-6VTX
Epox MVP3G2
MSI KT7 TURBO2
Reply 16 of 21, by PC Hoarder Patrol
I posted this one for @SET BLASTER who was also looking for the GA-6VTX
Re: The "Driver CD" for motherboards thread
It covers a number of their VIA boards from around that time (2001) so maybe yours is included as well - mine are all the 6VTX series dual boards (6VTXD, 6VTXDR-C)
Reply 17 of 21, by zPacKRat
PC Hoarder Patrol wrote on 2020-06-07, 00:19:
I posted a link to the pa2013 disk contents recently and I shared out the link and someone put it up on vogondrivers on my behalf for everyone.
Reply 18 of 21, by PC Hoarder Patrol
Horun wrote on 2020-06-06, 03:30:
Gigabyte 8IPE1000MK
609.11 KiB
GA_865_875.txt
3.04 KiB
54 downloads
http://www.mediafire.com/file/94jjol2ibvpons7 … 65_875.zip/file
Reply 19 of 21, by Horun
PC Hoarder Patrol wrote on 2020-06-07, 19:27:
Gigabyte GA-8IPE1000MK.jpg […]
Gigabyte 8IPE1000MK
GA_865_875.txt
Thanks ! Got it !
