First post, by ildonaldo
I've just got a new cooler for my Pentium II built that I can't make heads or tales of.
It is called "Pentalpha, EISCA Cooler ", obviously it's a SECC Cooler but it comes with a strange interface/header on the front (see images below).
The cable "might" suggest a USB2 connector, but the connector on the cooler doesn't.
It also comes with two addional plastic pins that are shorter that the SECC locks and removable feet (see first image, front).
The disk, that came with the cooler did not contain any clue (or manual).
Has anyone got an idea what it is for or how it works?
TNX & regards
110.9 KiB
GPL-2.0-or-later
141.74 KiB
Pentalpha, EISCA Cooler - Header
GPL-2.0-or-later
64.34 KiB
Pentalpha, EISCA Cooler - Cable
GPL-2.0-or-later
39.48 KiB
GPL-2.0-or-later
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
Reply 2 of 8, by ildonaldo
Yes, both ends are identical.
The only additional information I've found so far is this patent no. ...
5.89 KiB
pantent information EISCA
GPL-2.0-or-later
Reply 4 of 8, by PC Hoarder Patrol
You'll need a compatable mainboard with a suitable I2C header. Here's some info based on the earlier socket 7 version
https://web.archive.org/web/20000612032342fw_ … ct/sk7EISCA.htm
Haven't looked that closely, but found one board - the Shuttle HOT-661V Apollo Pro Plus Slot 1 - with the header (try Googling EISCA mainboards)
Reply 5 of 8, by Ozzuneoj
Interesting! I've never seen one of these before. Looks like an early version of the motherboard-controlled PWM fans we have now. Seems like overkill for processors that have static clock speeds and voltages.
