First post, by Vany
I was wondering what the best operating system would be for this machine. I'd like to run late 90s games on it but some are completely incompatible with Windows 2000 that it currently has. I was planning on putting Windows 98SE on it but there's no drivers for that os. Would Windows ME be a decent option in this case?
Trident Cyber 9525DVD Test, Review and supported games list
Reply 1 of 9, by schmatzler
Vany wrote on 2020-02-15, 15:30:
Yes there are:
https://thinkpads.com/support/Thinkpad-Driver … /ddfm/A30p.html
Just choose ME as the OS and all the Win98 drivers will show up.
Reply 2 of 9, by Vany
schmatzler wrote on 2020-02-15, 18:17:
Yes there are: https://thinkpads.com/support/Thinkpad-Driver … /ddfm/A30p.html […]
Yes there are:
The problem is that some drivers aren't there even under that, for example the display driver.
Reply 3 of 9, by schmatzler
Of course they are, just look carefully.
11.79 KiB
Even my A31p works with Windows 98, the A30 will certainly do, too.
Reply 4 of 9, by Vany
schmatzler wrote on 2020-02-15, 19:02:
When I click on that page it shows just the monitor file?
EDIT: Nvm, the driver is on the page, it's just not sorted under any OS. Thanks!
Reply 5 of 9, by dr_st
That sound chipset does not have DOS support, and for Windows-only games I would put WinME over 98SE anyways.
What intrigues me is the status of AC97 sound support for DOS games played under Windows? Does it exist? Does it require VXD drivers? Do these drivers work better under 98SE than under WinME?
Reply 6 of 9, by Vany
dr_st wrote on 2020-02-15, 19:31:
I am not sure exactly what you mean but I think it supports MPU-401 and I plan to use WinGroove with that, will make dos games sound decent if it works!
Reply 7 of 9, by schmatzler
The audio drivers have SoundBlaster emulation for DOS games within Windows.
It can be enabled through the device manager.
Reply 8 of 9, by crazii
schmatzler wrote on 2020-02-15, 22:24:
I've read the A31p's driver has soundblaster emulation, Re: Windows 98se compaq evo n610c no sound in dos games , It's a VXD driver with GM MIDI virtual service for DOS, and I've tested the driver with my soundmax card and it's not working good, sound driver setup can't recognize the SB 'hardware' but old DOS games can.
I'm planning to get a A30p and I checked the driver from IBM, and it has soundblaster emulation. Here's INF:
[Strings]
String0="Crystal Semiconductor"
String1="Crystal Semiconductor"
KEY_IOC="SYSTEM\CurrentControlSet\Control\MediaResources\InstallOptionalComponents"
KEY_BASE="SOFTWARE\Crystal Semiconductor\CS461x"
SYNTH_BASE="Software\Crystal\CrystalWave\0.0"
DeviceDesc="Crystal Audio Codec"
BlasterDesc="Crystal Audio Codec Game Device"
MediaClassName="Sound, video and game controllers"
CSMfgName="Crystal Semiconductor Corporation"
CSSYNTH.DeviceDesc="CrystalWave Synthesizer"
ProviderCrystal="Crystal"
V_CLSWAVEFORM="Audio"
V_CLSMIDI="MIDI"
V_CLSMIXER="Mixer"
V_CLSAUX="Auxiliary"
V_INTERNAL="FM Synthesis"
V_EXTERNAL="External MIDI Port"
So would you bother to share the compatibility of the A30p driver's emulation? If it works for most DOS games (both digital sound and music) then I'll definitely get one.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 9 of 9, by TAYMON
Although this is old, maybe you still have your Thinkpad. I have the A30P version that runs witrh Windows SE.
When it comes to Sound there is one more very interesting option. I got my hands on an IBM Dock 2877. It allows to install a PCI-card, so I upgraded the system with a Soundblaster Live card.
There are excellent guides online to set it up for Windows 98SE. Making it a great soundcard for retro gaming, since you also get a real gameport.
https://www.philscomputerlab.com/sound-blaster-live.html
See my setup in the attached photos.
165.43 KiB
Soundblaster Live CT4380
1.17 MiB
A30P with Dock 2877 running Windows 98 SE
