First post, by aaronkatrini
Hi all,
A friend of mine was cleaning his attic and found among other stuff these 9 AMD 286 CPUs. And they look so cute, so tiny. I asked him for one, just for the looks (so cute and tiny). They should be the same, all 12mhz pieces...Which one do you think I should choose?
My interest for the time being to the 286 era is about just curiosity, no actual interest to build a system, and the cpu I will get will be put on on a frame for displaying purposes.
Thanks in Advance! 😀
Reply 3 of 4, by Vynix
Those are CLCC (Ceramic Leadless Chip Carrier) Am286-12s, pretty much your run-of-the-mill 286, nothing less, nothing more. Though that the CLCC variants seem to be on the uncommon side, and I'm not sure if they will even fit into a PLCC (Plastic Leadless Chip Carrier) socket.
Reply 4 of 4, by imi
only for display purposes probably the one in the top left (bottom left if viewed correctly) as it seems to be in best shape and have a clean surface, though the ones with the large AMD logo also look nice ^^
