VDMSound refuses to run
First post, by thetaxcollector
Hi, I think you've got a great program here, but I cannot use it on my PC, because when I start it with "dosdrv" in CMD it starts to load then brings up this error.
Instantiation - COM Error
Unable to instantiate Emulation Module "VDMServicesProvider".
0x800401f3 - Invalid class string (C:\Progra~1\VDMSound\VDMS.INI:66)
Do you want to continue...
Can anyone help me get this working?
Reply 1 of 14, by MiniMax
Rank Moderator
Moderator
Which version of VDMSound?
Which OS?
_________________
Reply 2 of 14, by Guest
Im running windows XP home with service pack 2
and VDM Sound version 2.1.0 beta
Reply 3 of 14, by MiniMax
Rank Moderator
Moderator
2.1.0 beta comes with this wonderful LaunchPad extension, whereby you right-click on the program to start it together with VDMSound. Why are you trying to start dosdrv manually?
_________________
Reply 4 of 14, by thetaxcollector
again thats another thing that works on the laptop but not on the PC but the pc is the one I really want to play it on. If I right click on TOMB.EXE there is no option for starting VDMS.
I have tried reistalling VDMS
Reply 6 of 14, by Guest
Thats not the problem I cant get VDM sound to run, Your topic has nothing on this problem, It tells you how to setup tombraider but not how to solve prblems with VDMSound
Reply 7 of 14, by MiniMax
Rank Moderator
Moderator
TTC, as per this thread, you might have to re-register the Active Template Library before re-installing VDMSound:
C:\> regsvr32 atl.dll
(edit: Fixed typo's)
_________________
Reply 8 of 14, by Guest
thanks, but windows XP home doesn't recognise it as a valid program or command
Reply 9 of 14, by MiniMax
Rank Moderator
Moderator
My bad 🙁 Spelling error....
H:> chdir /d %systemroot%
H:\WINDOWS> dir /s /b regsrv32.exe
File not found.
H:\WINDOWS> dir /s /b regsvr32.exe
H:\WINDOWS\system32\regsvr32.exe
H:\WINDOWS\system32\dllcache\regsvr32.exe
The program is regsvr32.exe
_________________
Reply 10 of 14, by Snover
You also wrote "atl.dll" as "atl.ddl" 😉
Yes, it’s my fault.
Reply 11 of 14, by Guest
Thanks, now VDMS starts ok, but when I get into the game, the sound is all stuttery - kind of like a cd skipping
Im beginning to think its not worth bothering.
Oh I dont know if this helps, but in VDMS I had to change the IRQ to 5 because it froze the game on 7 - is it possible its conflicting with my soundblaster live card?
Reply 12 of 14, by eL_PuSHeR
Did you try fiddling with VDMSound's advanced option tab? specially, the cap timer feature and use a certain amount of cpu power. 😕
Reply 13 of 14, by MiniMax
Rank Moderator
Moderator
That's the problem with old age. I forget to take my medicine 😀
_________________
Reply 14 of 14, by Snover
No; probably the game is configured for IRQ 5. There can be no conflict between your actual hardware and the virtual DOS machine's virtualized hardware unless you are using a passthrough (this is what SoundFX does).
Yes, it’s my fault.
