OPL3LPT + Soundcard?
First post, by Der Kuenringer
Would it be possible to make an OPL3LPT & an SBPro compatible soundcard (Aureal Vortex 2 in my case) work in tandem for sound output in DOS?
If possible, I trying to find a way to bypass the FM emulation of the Vortex 2, to get FM synth through the OPL3LPT, and speech/sfx from the Vortex 2.
Reply 1 of 4, by carlostex
Well it is possible, as soon as games are patched to output to OPL3LPT instead of the default AdLib port, and also Patch the games that output to 2x8/2x9 for the OPL3LPT then the FM emulation on the Vortex wouldn't play, and you could route the OPL3LPT to the line in of the Vortex instead.
Reply 2 of 4, by Der Kuenringer
Thank you btw, better late than never 😜
Going to try this out with an upcoming build, since I can only fit one soundcard. I'm surprised that nobody seems to have gone down this road yet, given the popularity of thin clients for DOS gaming.
Reply 3 of 4, by Der Kuenringer
To spin this a bit further, and since I have no experience with WaveBlaster add-on boards:
Would using a Creative Waveblaster (II) with it's EMU8000 allow me to add reverb & chorus to my OPL synth, given my OPL3LPT/Vortex setup?
Reply 4 of 4, by TechieDude
No, since the Waveblaster (and any other Wavetable add-on board) is basically an external MIDI module that can sit on your card instead of taking space on your desk. It doesn't give you as much control as a full AWE card.
