First post, by dizM0nkey
Hello,
Relatively new to exploring options with DOSBox (I've been using it for ages but haven't dug into settings much and just learning about SVN options). My goal is to get ~5x scaling with HQ or BRZ or something that smooths the edges a bit these older games.
I'm using DOSBox Game Launcher 9.1 and have imported tons of my profiles already. I've got the default DB7.4 and also added DBECE as I saw that scalers for 4x-6x were available (they've been added to scaler options in DBGL)
I don't know if I should have or not, but I've added all the below resolutions to my "Dynamic Options" though few seem to work; only scaling options seem to work. I think I borked it so will need to load default values again.
I've also seend/heard/downloaded and tried xBRZ but can't seem to get it to work... what parameters do I need to set for scaling / window size to work? I've tried the following with xBRZ flavor of DB:
BRZ2x
BRZ3x
BRZ4x
BRZ5x
BRZ6x
and
2xBRZ
3xBRZ
4xBRZ
5xBRZ
6xBRZ
Neither options seem to work and can't find instructions / readme as to which options need to be set for scaler.
aforementioned Resolutions added to fullresolution and windowresolution
Details
original
desktop
0x0
320x200
640x480
800x600
960×720
1024×576
1024x768
1152×648
1280×720
1280x768
1366×768
1280×800
1280x960
1280x1024
1440×900
1400×1050
1440×1080
1600×900
1600×1200
1680×1050
1856×1392
1920×1080
1920×1200
1920×1440
2048×1536
2560×1440
2560×1600
3840×2160
Any help is appreciated.
Reply 2 of 2, by junglemontana
Perhaps you already know this, but if the original resolution is above a certain limit, you have to add "forced" after the scaler option, otherwise it won't activate. And there are also hard-coded resolution limits that disable scalers and they can only be overridden by patching Dosbox.
I don't know about xBRZ or other custom-patched versions of Dosbox.
Also note that the HQ scaler is rather heavy so unless it's hardware-accelerated (or at least multithreaded) you may not achieve good performance for 5x scaling.
