Reconfiguring Games
First post, by T
When VDMSound is run the first time on a game it asks if you'd like to use an existing configuration or create a new one. I recently ran a game and selected an existing configuration. Is there a way to edit the configuration for this game now that it's been set? Thanks!
Reply 1 of 10, by eL_PuSHeR
Yes. It's very easy. Just right-click on the .VLP shortcut. Then edit its properties. 😎
Reply 2 of 10, by Guest
Thanks for the reply. That does not do what I want to do though. Specifically I'm trying to get "Age of Rifles" sound working. When I ran VDMSound the first time I ran AOR I used the default settings, but the sound doesn't work. Then I saw this url:
http://www.wargamer.com/aor/vdms.asp
which details how to set different parameters. The problem is I don't know how to edit these parameters after the defaults are chosen. When I right click and do a properties there is not a lot to change. Thanks.
Reply 3 of 10, by MiniMax
Rank Moderator
Moderator
Anonymous wrote:
When I right click <snip>
Right-click on WHAT?
_________________
Reply 5 of 10, by Zebius
Did you click 'Advanced' button in properties of .vlp file? There are many things you can change there 😀
Reply 6 of 10, by T
Yes I did, and there is not much there, just some archive and index attributes and some compress and encrypt attributes.
Reply 7 of 10, by Zebius
There should be 'VDMSound' tab in properties window (on top). Switch to that tab, and then click 'advanced'.
If there is nothing there - something went wrong with your VDMSound installation, reinstall VDMSound.
Reply 8 of 10, by T
Well it seems that I was running an older version of the software, when I upgraded I now see all of the options. Thanks for all of the quick and informative replies guys!!
Reply 9 of 10, by Guest
Me and a company of a friends decided to meet Christmas in Moscow,
can anyone tell us were to find an apartment?
Thanks, John.
Reply 10 of 10, by MiniMax
Rank Moderator
Moderator
If you meet this Cristmas guy in Moscow, say "hello" to him from me, will you?
_________________
