Window Size Reverting
First post, by npilot
Hi all,
I'm running Dosbox 0.74 on Linux Mint and keep running into a frustrating problem.
I'd like to play my games windowed at 1280 x 1024 - I edited my dosbox config to:
fullscreen=false
fulldouble=false
fullresolution=desktop
windowresolution=1280x1024
output=overlay
hwscale-2.00
autolock=false
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=false
When I run Dosbox, the window size is set correctly in the initial shell. I CD to the game I want to play and run the exe (Aces of the Deep), but as soon as the game loads the window size reverts to what I assume is the default 320 x 240 (it's really small).
Any ideas why this is happening? I looked for a conf in the game folder itself to see if a game's resolution setting was overriding, but no dice.
Reply 1 of 2, by DosFreak
The original resolution of the game is likely 320x.
Judging by the conf I'm guessing you're using an unofficial build of DOSBox. The latest official version is 0.74-3
For DOSBox on Linux you should be using output=opengl assuming your hardware is capable to use it. You can use scaler= to increase the resolution.
If you are using a recent SVN release of DOSBox you can set the resolution fields to a percentage of your screen size.
DOSBox uses a central configuration file in .dosbox in the root of your profile. You can edit that one or create a new one and launch DOSBox with it.
Make your games work offline
Reply 2 of 2, by npilot
Thanks for the info, DosFreak! I'll do some tinkering and post a solution if I find it.
