Modem emulation issues
First post, by Nicknine
I was originally contemplating making a separate topic for each game but I suspect that all of this might be connected. DOSBox modem emulation appears to be unstable as I'm facing several problems in different games/apps.
1) Modem commands would sometimes arrive with garbage mixed in as seen in the console.
2) Duke Nukem 3D crashes on the calling DOSBox instance when starting a level in modem play with "INVALID GAME PACKET!!! (6 too many bytes)" error while DosBox console spams "illegal read" errors. Curiously, this does not happen if two DOSBox instances are linked together with a comms program like Telemate and "Already connected" is selected in Setup program.
3) Doom has the reverse issue. Making the call using Setup appears to be working fine but if two DOSBox instances are linked together first and "Already connected" is selected in Setup program then the game hangs at startup screen after "V_Init: allocate screens" message.
4) The Need for Speed: Special Edition runs at single digit framerate in modem play.
Now, I know that non-gaming apps are not officially supported but the following could be symptoms of a bigger issue so I think it's worth looking into.
5) Issues with file transfer over modem connection (e.g. on BBS boards). No matter which protocol is used, the transfer starts throwing errors and then fails partway through.
6) If I connect to FTP server via modem (yeah, I know it's not the correct way to use FTP server but it's a good illustration of the issue) about 40% of the time commands arrive with garbage mixed in.
It kind of seems like modem's command/data buffer gets corrupted? None of this happens with null-modem emulation as far as I can tell. I have also tested multiple builds (latest SVN build, 0.74-3, 0.65, even DOSBox-X) and they all have these problems. According to the repo there have been no major updates to modem code since 2009 which would explain it.
Reply 1 of 19, by Nicknine
Looking at the code, it could be that CFifo class is bugged? I'm not seeing anything that could corrupt the buffers themselves and issues occur with both command input and received data.
Reply 2 of 19, by jmarsh
If the BBSes are telnet-based you need to issue the ATNET1 command before dialing.
Reply 3 of 19, by Nicknine
jmarsh wrote on 2020-02-27, 23:52:
Yes, I'm aware. Issues #5 and #6 describe behavior with telnet mode enabled with ATNET1 command.
Reply 4 of 19, by krcroft
On sourceforge, Marco Maccafferri posted a fix addressing at least some of these issues: https://sourceforge.net/p/dosbox/patches/287
To test it, you need the patch applied to both your DOSBox as well as the BBS's server-side DOSBox (assuming the BBS itself is running under DOSBox).
If you don't have a build environment setup to try patches, then you can try one of the binaries from dosbox-staging (https://github.com/dreamer/dosbox-staging), which accepted Marco's patch a couple weeks ago: https://github.com/dreamer/dosbox-staging/pull/172
Also of note are the com port settings, mentioned in section 9, Serial Modem, under the "BBS Gaming" subsection:
https://github.com/dreamer/dosbox-staging/blob/master/README
Curious if any of this helps.
Reply 5 of 19, by Nicknine
Thanks, I'll give it a shot!
Reply 6 of 19, by Nicknine
Well, I've compiled the patch and it was of no use whatsoever, it didn't resolve any of my issues. It looks like it's only intended to fix file uploading. But at least I have the build environment set up now so I can try and do my own investigation.
EDIT: Ok, found a bug with backspace handling at line 686, if you type backspace while cmd buffer is empty, it will write backspace symbol to the buffer and screw up the command.
EDIT 2: Seems like backspace characters are what is screwing up FTP server commands as well. This is not a DosBox bug, however, this seems to be a problem with how FTP server handles backspace.
EDIT 3: Duke Nukem 3D sends three ESC (0x1B) chars to the modem before init string which are not handled by virtual modem. Not sure what this is, kind of looks like escape sequence?.. Making the command parser skip those seems harmless although it doesn't fix invalid packet crash.
EDIT 4: Doom issue appears to be gone, maybe I was doing something wrong.
EDIT 5: This still leaves 3 issues out of 6, I don't think I can figure those out.
EDIT 6: Duke Nukem 3D crash only appears to happen on version 1.3D (original retail release) and it's the only version to send 3 ESC characters. There might be a connection. I'm thinking it's a bug because I've checked several pages detailing Hayes command set and there's no mention of command mode handling ESC character.
Reply 7 of 19, by jmarsh
I saw the same behaviour with Duke3D (1.3D) but every few tries it would actually work correctly; the data being transferred to/from the game was exactly the same in all cases so it looks like it's just some internal state bug in the game.
Reply 8 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 07:44:
Has it been tested on the real hardware? I might be able to do that once I get that Retro WiFi SI modem.
EDIT: I've re-tested NFSSE using two instances on the same machine (instead of one of them running on an old WinXP rig) and it doesn't drop to single digit framerate. However, it still runs worse than in singleplayer. This suggests that modem play in NFSSE is extremely taxing under DOSBox for some reason to the point where the game becomes unplayable on Pentium 4.
Reply 9 of 19, by jmarsh
Modem emulation uses blocking TCP transfers, null-modem uses non-blocking. Like I said in the other thread, it's preferable to use null-modem whenever possible.
A wifi "modem" won't accurately emulate a serial port+hardware modem combination any more than DOSBox does already.
Reply 10 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 12:51:
Considering the data sent is the same, it seems more like a CPU emulation issue and not modem issue.
Reply 11 of 19, by jmarsh
No. Interrupts are not predictable, even with fixed clock speeds. The fact that the game wanders off and tries to execute unmapped memory is a dead-giveaway that it's bugged.
Reply 12 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 13:04:
It seems highly unlikely to me that the game shipped with a completely broken modem support.
Reply 13 of 19, by jmarsh
You mean like all the games with adlib detection routines that fail on any PC made after ~2000?
Reply 14 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 13:31:
But they weren't broken at launch, were they? I don't understand your point.
Reply 15 of 19, by jmarsh
Just because something worked (sometimes) at launch, doesn't mean it isn't bugged.
Reply 16 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 13:40:
By that logic the majority of DOS games are bugged since most of them have compatibility issues on newer hardware. But the whole point of DosBox is to emulate old hardware to address that. I think it's reasonable to assume that DN3D wasn't broken at launch and, as such, this is DosBox compatibility issue.
Reply 17 of 19, by jmarsh
You think they would have patched the code if there was nothing wrong with it?
Reply 18 of 19, by Nicknine
jmarsh wrote on 2020-03-01, 14:54:
What? I'm not saying the game wasn't bugged, period; I'm saying that the current issue where the game crashes (almost) every time when you start a modem play was not present on the real hardware at launch.
Reply 19 of 19, by krcroft
Nicknine, even though ATNET1 works for small downloads, I have also confirmed that large downloads (ie: DOOM shareware, ~1.2 MB), fails after 5+ minutes downloading; like you've suggested.
This was confirmed when downloading DOOM1_2A.ZIP from bbs.dmine.net:24, using DOSBox at 6000 cycles running Terminate 5.00 with the serial port set to 19,200 baud.
