First post, by pest
hello!
i've a problem with ver 0,63:
on opening a dos program under doxbox emu, the emu crashes an leaves the following message:
DOS:0x65:unhandled country information call 21
i've no idea what to do.
is it possibe to create a config.sys file to load some county parameters?
if yes, where should i place the file?
thank you!
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
You are in a wrong forum (DOSBOX has nothing to do with VDMSound)...
If you post in a proper forum (or somebody moves this thread there) together with more details (what program...), then maybe somebody from developers will notice you and add it for future version.... NO GUARANTEE (I am not developer!)
Mirek
