First post, by spark2k06
After getting ideas from here and there, I have started the development of a double project consisting of an 8-bit graphics card based on the IC RTG3105iEH and in PC/104 socket, which makes it compatible with the new one NuXT v2.0 and on the other it is also with the other project I have gotten into, a converter to ISA 8/16 bits from this type of socket with MonochromeVGA incorporated:
For the development of the Realtek graphics card, I had no choice but to do buy on eBay and carry out a reverse engineering process, in the absence of datasheet information or public schemes. They are still in the routing review phase and final connector positioning adjustments ...
5k8cill2GAnLGp7jTfobVN5iqwwQh4MhGbELXelvtPd4UK65Lk7VfHfGGU5ZEobDjhIYXfBltJYd6FqlusdO_dVlIQA6bDZGxjCiYlDv4RBMo3Vwo6kayP4ALOt8uh3jvgqedvDGu14=w1218-h578-no
oasDTDMUUGpZYPbgeDlFE4doJPYn346m3WiY2faTQDYttuLVd4NDPhQyIbZi41TzWZlrThmJ54ZRPECLRE7F0nWvo9A5HKlH49MJKRUuXIm7kNd3bp_cZ5uXn636zJyI36lEBguPJw8=w1218-h578-no
https://www.tindie.com/stores/spark2k06/
https://hackaday.io/spark2k06
Reply 2 of 14, by digger
Interesting. So why will NUXT v2.0 have a PC/104 slot/socket for graphics cards as opposed to an extra standard 8-bit ISA slot? Is it perhaps because 8-bit compatible VGA cards with PC/104 interfaces are still being manufactured and sold due to demand for industrial/embedded systems?
Reply 3 of 14, by Jo22
Cool! 😎 The green acrylic I/O shield is one thing that impresses me the most.
Edit: I've seen a similar design in on older 286 systems a few times, mainly industrial ones.
If memory serves me well, then the daughter card was a VGA compatible design based on the Paradise chipsets.
digger wrote on 2020-03-21, 13:17:
Good question. What makes me wonder is, why homebrew projects rarely seem to support these pin holes found on older ISA cards.
You know, these which are located near the edge connector. These would allow to piggy-back some daughter cards.
Source: https://commons.wikimedia.org/wiki/File:EISA_ … thernet_NIC.JPG
Reply 4 of 14, by spark2k06
PC104 8/16 bits SVGA to ISA BUS + #MonochromeVGA, a low cost prototype in times of coronavirus. Definitive position of external connectors, the switches will be totally hidden with some piece of plastic. Now rerouting...
Xp9_eTWNArVaZUGklmw6Zn7mTW00j1fxh6y7XGpU0ca-aHLJX6nraOkgF9NjzLSFVxcllByxlwidyT1kcCpWbCIJ5GiYYXUyK6bPy925F2_rTQaJEJkcR4DjEK7rMX88YkdmzVyWZKY=w1194-h897-no
https://twitter.com/spark2k06/status/1254004466711433221
Reply 6 of 14, by pentiumspeed
Yes there was one of PC which was Dell 486 with cache and had Tnesg ET4000 on daughter board connected to those pin connectors at that location.
Cheers,
Great Northern aka Canada.
Reply 9 of 14, by RealityTech
Sorry for thge Necro Thread
What happened with this, most of the links here are now dead. I'm about to start reverse engineering over again for my Amstrad PPC expander and would be useful to not have to start over 😀
Reply 11 of 14, by RealityTech
@matze79 I have done. I started buzzing the card I have out then stopped. The triden is only more complex in a few small ways, mostly it has a more "tricky" package and needs a BIOS but tobh the real estate I have and the fact I may put the VGA for this project on a PC104 mezzanine card makes the Trident a better choice as it's been done already. I've ordered the PCB and some TVGA9000 chips so I think this is really a dead end.
A mezzanine also makes more room for other upgrades 😉
Reply 12 of 14, by itsemast
I recently also discovered this tiny chip that integrated both DAC and BIOS, but completely lacks documentation. It seems that the schematic is now gone from GitHub, and someone just bought all the remaining supplies of RTG3105iEH from Utsource... How unfortunate!
Reply 13 of 14, by RealityTech
I'm not sure it's worth the extra greif. Its not actually a very good card and the TVGA chips are still available as are PCBs. This arrived the other day and just waiting on chips now....
The attachment PXL_20251106_102610783.jpg is no longer available
Reply 14 of 14, by RealityTech
Just managed to get my realtek card to start and holy moly its slow. Even on an XT, Would love to know the fill rate.
