First post, by icemann
- Member
Hey all
I`ve run into some problems whenever I attempt to install 7th Guest. At first I got the old "mscdex not installed" error message which the "mount d f:\ -t cdrom -usecd 0 -ioctl" line from the readme file fixed.
But after getting into the installer and setting where to install the files I noticed the following line appearing a substantial amount of times in one of the dosbox boxes:
SHELL:Redirect output to nul
The installer itself seemed to progress through the files fine, but in actual fact, no files were installed to my system and the installer later froze once it got to "readme.txt" and I had to close dosbox after that.
The exact same thing happens if I try to install it in windows xp strangely enough except that the files before readme.txt get copied to my actual computer.
Any help in managing to get this game installed would be most helpful 😀.
Two stones, two crosses, the rest is just icing. - 7th Guest
