First post, by Lylat1an
I apologize if this has been asked before.
I'm trying to run a game in addition to a program that translates a gamepad to keyboard inputs.
The game works fine on its own, but running them together gives me an "Out of memory" error.
Is there a way to make them run in high memory to avoid this issue?
Reply 1 of 19, by BinaryDemon
You should be able to load your 'translation program' high. Maybe try QEMM or another 3rd party memory manager.
I doubt you want to load the game high, some games have their own protected mode extenders which give them access to all the available memory.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 2 of 19, by Lylat1an
BinaryDemon wrote on 2020-03-15, 03:58:
That sounds like it would work, but how do I do that?
Even with a 3rd party memory manager, wouldn't I still need to type something extra to tell the translator to load in an higher memory location?
Reply 3 of 19, by BinaryDemon
If your loading the translator program in autoexec.bat you can use LH or LOADHIGH in front of the executable path.
Reply 5 of 19, by Lylat1an
I'll try loading it in autoexec.bat tomorrow, too sleepy tonight.
Turns out I can't load the translator high because it is also a batch file.
If it helps, the translator is called SNESKey. I'm not seeing any documentation that addresses memory issues.
Reply 6 of 19, by derSammler
Then edit the batch file of the tool and add "LH" there for the .com or .exe it loads.
However, It's most likely too big anyway, as high memory is limited and you have probably some stuff sitting there already.
Why not post your config.sys, autoexec.bat, and the output of "mem /c /p" here? Much easier to help then.
Reply 7 of 19, by Lylat1an
derSammler wrote on 2020-03-15, 08:32:
Editing the batch file with LH breaks the file location. 🙁
I'm sure these files could use some cleaning up, but here they are:
CONFIG.SYS (USB drivers at the end didn't work right, commented them out until I figure out why)
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=15,0
FILES=40
DOS=UMB
LASTDRIVE=F
FCBS=4,0
DOS=HIGH
;DOS=UMB
REM ** FILES=30
DEVICEHIGH /L:2,12048 =C:\DOS\SETVER.EXE
DOS=HIGH
;device=C:\USB\USBASPI.SYS /w /v
;device=C:\USB\NJ32DISK.sys
[common]
DEVICEHIGH /L:2,17200 =C:\CDROM\AOATAPI.SYS /D:IDECD000
AUTOEXEC.BAT
SET SOUND=C:\SB16
SET BLASTER=A220 I7 D1 H7 P330 T6
SET MIDI=SYNTH:1 MAP:E
C:\SB16\DIAGNOSE /S
C:\SB16\MIXERSET /P /Q
@ECHO OFF
LH /L:0 C:\DOS\SMARTDRV.EXE /X
PROMPT $p$g
PATH C:\DOS ;C:\SNESKEY
SET TEMP=C:\DOS
LH /L:2,27952 C:\DOS\MSCDEX.EXE /D:IDECD000
SET LMOUSE=C:\MOUSE
C:\MOUSE\MOUSE.EXE
MEM /C /P
Modules using memory below 1 MB:
Name Total = Conventional + Upper Memory
MSDOS 14,957 (15K) 14,957 (15K) 0 (0K)
HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
EMM386 3,120 (3K) 3,120 (3K) 0 (0K)
COMMAND 2,928 (3K) 2,928 (3K) 0 (0K)
SMARTDRV 29,024 (28K) 29,024 (28K) 0 (0K)
MOUSE 24,176 (24K) 24,176 (24K) 0 (0K)
SETVER 512 (1K) 0 (0K) 512 (1K)
AOATAPI 10,352 (10K) 0 (0K) 10,352 (10K)
MSCDEX 27,952 (27K) 0 (0K) 27,952 (27K)
Free 586,912 (573K) 573,680 (560K) 13,232 (13K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 649,216 75,536 573,680
Upper 52,048 38,816 13,232
Reserved 0 0 0
Extended (XMS)* 15,676,592 2,602,160 13,074,432
Press any key to continue . . .
Total memory 16,377,856 2,716,512 13,661,344
Total under 1 MB 701,264 114,352 586,912
Total Expanded (EMS) 16,056,320 (15,680K
Free Expanded (EMS)* 13,320,192 (13,008K
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 573,424 (560K)
Largest free upper memory block 9,024 (9K)
MS-DOS is resident in the high memory area.
Reply 8 of 19, by derSammler
Wow, that's quite a mess. But anyway:
1. add "HIGHSCAN I=B000-B7FF" after the "RAM" parameter of EMM386
2. remove all "DOS=" lines and just add "DOS=HIGH,UMB" once
3. remove SMARTDRV.EXE
4. use CuteMouse instead of that MOUSE.EXE
This should give you about 50-60 kb more conventional memory.
Also, remove all that "/L:x,y" stuff. I guess you did run memmaker at some point?
Reply 9 of 19, by Lylat1an
derSammler wrote on 2020-03-15, 18:13:
Wow, that's quite a mess. But anyway: […]
Yes, I ran memmaker.
CuteMouse couldn't find my mouse, so I commented out the lines for both mouse programs and the game still won't load.
Reply 10 of 19, by Jo22
Is there a way to load DOS games into high memory?
Yes, if you mean the range of 640KB to 1MB (aka adapter space, adapter's segment, Upper Memory Area/UMA).
Problem is, the term for that region varried. Both in time and space (country).
Originally, in English countries, that space was called "high memory". This was in the mid-1980s or so,
when people tried to make their old PCs make use of more system memory for DOS (conventional memory rather than UMBs).
At the time, with Hercules and CGA cards, it was possible to have 704 to 736KB (and beyond with other gfx hardware) of ordinary DOS memory,
provided the motherboard was configured that way..
A proof-of-concept video of mine can be seen at https://www.youtube.com/watch?v=8nMB8XvwUJo
Later, after XMS came out and Himem.sys was able to use 64KiB (-16bytes) above 1024KB -on ATs- to swap out DOS kernal,
it became "upper memory" (with free memory blocks called UMBs; Upper Memory Blocks).
In German speaking countries, for example, this was not adapted until the release of DOS 7 for several reasons.
In DOS 6.22, the Upper Memory Area (UMA) is erroneously called "Hoher Speicherbereich" (high memory location),
and the HMA (High Memory Area) is called "Oberer Speicherbereich" (upper memory location),
causing confusion with English speaking folks sometimes. Especially when they're around on English forums. 😉
More information:
https://de.wikipedia.org/wiki/High_Memory_Are … riffsverwirrung
Englisch Translation
Reply 11 of 19, by derSammler
Lylat1an wrote on 2020-03-15, 23:51:
Did you do the other changes I suggested, too?
Reply 12 of 19, by Lylat1an
Upon further investigation, the issue seems to be that the combination of the two programs are just too large to fit in conventional memory.
The game needs 560KB, SNESKey is 57KB, together they equal 617KB out of the 602KB total conventional memory available.
Is there a smaller alternative to SNESKey that will let me use a game controller to emulate a keyboard? Or a way to load SNESKey into a higher memory area?
Reply 14 of 19, by Lylat1an
derSammler wrote on 2020-03-21, 22:10:
There's no issue getting 617 KB or even more. And you can load SNESKey into high memory.
Oh good, how can I do that?
I did use your suggestions, I also removed the USB lines and commented out the mouse lines.
I can post my new files if it will help.
Reply 15 of 19, by Lylat1an
I rearranged DOS's Autoexec and Config files and now I have enough memory to load the two programs together in conventional memory.
Still, the game crashes sometimes saying it ran out of memory.
Reply 16 of 19, by digger
Jo22 wrote on 2020-03-15, 23:52:
In German speaking countries, for example, this was not adapted until the release of DOS 7 for several reasons. In DOS 6.22, the […]
First of all, to be fair, "upper" and "higher" are basically synomyms, so it would be hard to keep any distinction between the two when trying to translate both things literally. But why didn't those silly Germans just stick to the English acronyms, like we did in the Netherlands? Why unnecessarily add so many syllables, and introduce such confusion otherwise? ¯\_(ツ)_/¯
There was the HMA, and there were UMBs. Simple. And the fact that the former was in singular form with a definite article and the latter was plural, made the distinction even clearer. There was only one HMA, but there could be many UMBs, depending on the motherboard's chipset.
Reply 17 of 19, by Lylat1an
Well, since you bumped the thread...
Is there anything more I can do to increase the available conventional memory?
    MEM.TXT
    1.73 KiB
    87 downloads
    CONFIG.txt
    220 Bytes
    76 downloads
    AUTOEXEC.TXT
    329 Bytes
    65 downloads
Reply 18 of 19, by K1n9_Duk3
It seems odd that your system only has 649,216 bytes of conventional memory in total. Conventional should be 655,360 bytes total, or at least that's what I get on my systems.
It might help if you could also tell us which game/program it is that you're trying to get to run in combination with that SNESKey utility.
Some games (like Catacomb 3-D, Commander Keen 4-6 and BioMenace) try to allocate additional XMS memory via UMBs and will not be able to use XMS at all as long as you have the line "DOS=UMB" or "DOS=HIGH,UMB" in your CONFIG.SYS. Allowing DOS to use UMBs means that MS-DOS will grab all available UMBs at startup, so the game can't use them. Without "DOS=UMB", however, you won't be able to load any drivers or TSRs into high memory. Unless your drivers and TSRs are filling your entire upper memory, you might get better results by letting the game use the UMBs and loading your drivers and TSRs into conventional memory.
The best solution for these games is to have either a dedicated boot disk or a boot menu with a matching entry. Remove anything that isn't absolutely necessary to get the game running (CD-ROM drivers, mouse drivers etc).
Reply 19 of 19, by CoffeeOne
Lylat1an wrote on 2020-04-06, 21:38:
If you don't need EMS, you can use EMM386.EXE NOEMS instead of EMM386.EXE RAM
That gives you more free RAM
