First post, by aaronkatrini
- Member
Hi all,
I've received this Video Card and was curious of what chip runs on it. I've never encountered anything similiar.
It runs on PCI bus and it is branded as Olivetti one. Any ideas?
I saw the marking "GO2019" and with a some googling it came up as a "Vision-40" from these PDFs:
http://minuszerodegrees.net/manuals/Olivetti/Olivetti - Appendix C - Video cards used in Olivetti computers.pdf
https://secure.corradoroberto.it/doc/olivetti … stems2/cap1.pdf
https://secure.corradoroberto.it/doc/olivetti … stems2/capa.pdf
The heatsink seems to be glued into the chip and removing it would be a risk. Also on the VGA connector, one of the pin holes is blocked, so I couldn't connect the VGA cable.
My assumption is that it is a "S3" card, the name "vision" and also the layout of the board reminds me of a Virge card, but not sure...
Any suggestions are hightly apprisciated.
Thanks in advance 😀
