Dosbox on Android device
First post, by CarlDoyle83
Sorry a total novice here.
I'm trying to run championship manager 96/97 on my android device. I have downloaded dosbox manager and turbo. I have followed all the instructions to no avail. Please find attached a couple of screenshots. Could someone please point out where I am going wrong please.
Regards
Carl
Reply 1 of 5, by Falcosoft
CarlDoyle83 wrote on 2020-03-17, 23:44:
Sorry a total novice here. […]
Regards
Carl
'cd' means change directory. cm9697.exe is not a directory but the executable file of your game. That's why you get this error.
You should remove the last 'cd' command to execute the program itself instead of trying to handle it as a directory.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 3 of 5, by CarlDoyle83
Falcosoft wrote on 2020-03-18, 00:22:
Regards
Carl
Thats great, thanks for your help. yet getting "digital hardware not found, Run SETSOUND to select an appropriate digital audio driiver" message?
sorry for being a pain.
Carl
Reply 4 of 5, by gdjacobs
No worries. All these Droid builds make changes to vanilla DOSBox which makes it really difficult for the authors of vanilla DOSBox to support it. If you like, you can get DOSBox running on a PC or Mac then try working out any quirks for your mobile device after. It might be a good way to start learning about DOSBox and DOS gaming with solid access to help and information.
Reply 5 of 5, by CarlDoyle83
gdjacobs wrote on 2020-03-18, 02:49:
I'll do that. Thank you.
