First post, by daibido1123
Hi all, so I am on the hunt for a 5.25 Floppy drive, but first I am trying to find out which one is the best option. I'm looking for a unit that does not need a cardboard spacer when not in use, that is double-sided read/write, that can read and write on all standards of data density floppies, and is of solid rugged construction that needs minimal maintenance and easy to clean if needed. An internal unit would be preferred, but an external unit is also an option. This is for a Pentium Socket 3 build.
Thanks all for your time.
Learning without thought is labor lost; thought without learning is perilous
Confucius
Reply 1 of 3, by Errius
What do those cardboard things actually do? Is it to prevent damage in transit?
"AI Requires Proof That You Are Human"
Reply 2 of 3, by daibido1123
Yeah, they are to protect against the mechanism bouncing and damaging the head. Later and high-quality units had an anti-bounce mechanism, making the cardboard un-needed.
Confucius
Reply 3 of 3, by derSammler
These cardboard inserts are for protecting the drive during transport only. No drive needs them when "not in use". They prevent the heads from colliding and the sled from moving. That's it. No need to care about.
Doesn't exist. 5.25" disk drives are not compatible in such a way. If you use a HD 5.25" disk drive to write to lower density floppy disks, an actual low-density disk drive won't be able to read it.
