First post, by nuno14272
Heelo fellows
Hi have a Zida Tomato 4DPS 2.11 with a dx4-100 + 32mb fpm..
Installed a 1GB CF-Card, using ontrack. everything looks ok..execpt for the mouse.
I'm usinf bios 1.72f
so i've downloaded the CTmouse 1.9 -> put the line in autoexec.bat -> c:\utils\mouse\ctmouse.exe
put the cable in com1, the red stripe is in pin 1.. in bios put the comA and comB in auto..
when loading dos 6.22, it's says, cute mouse installed in com1 (03f8h/irq4) in mouse systems mode..
Seens instaled but i have no mouse, in dos or in windows.. tried diferent serial mouse's -> nothing. change the wndows setup for logitech -> nothing
THIS IS DRIVING ME CRAZY... what happening ?
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 1 of 9, by derSammler
Try a different COM cable. There are two versions of how it can be wired.
Reply 2 of 9, by nuno14272
update, after some searching in the web, i have a funworl logo on my boot screen.. this means i have a different bios ? but is marked 1,72f
derSammler - > what do you mean ? i've tested like 3 cables.. all look exaccly the same...
1| 386DX40
Reply 3 of 9, by derSammler
nuno14272 wrote on 2020-04-06, 10:51:
The wiring can be either pin 1>1, pin 2>2, etc. (left to right-order), or pin 1>1, pin 2>6, pin 3>2, etc. (zigzag-order)
You can't see the wiring from the outside and only the cable with the wiring used by the mainboard will work.
Reply 4 of 9, by nuno14272
on the motherboard... is:
678910
12345
not
246810
13579
hmmm
so.. it's diferent from other boards ?
1| 386DX40
Reply 6 of 9, by derSammler
It's about the pins inside the COM connector. Printing on the mainboard is always the same. As said, you can't see the wiring from the outside, nor is there any way to tell which of the two you need if you don't have the ones that came with the board. So you need to try both variants if one is not working.
Reply 7 of 9, by keropi
yes this is exactly what derSammler says, new COM cables will not work with older systems, the change was made in p1 era AFAIK
Reply 8 of 9, by nuno14272
update 1) the bord as a PS/2 header... if i use it... the keyboard stops responding.. doesn't wor any more.. strange..
update2) if i use a ISA COM card (just adds two more com ports, the mouse doesn't work either...
update 3) if i install a ISA IDE card.. (for old computer wihthout ide onbord), the mouse works.... for about, 3 or 4 seconds.. them the mouse freezes... either in dos or windows 3.11..
i'm getting out of ideas
1| 386DX40
