First post, by matze79
Hi,
i got a Luckstar Mainboard with S370, it has 100Mhz Bus Support
But i can`t get past Post with Coppermine CPU installed.
So i guess a BIOS Update is needed, but there are 3 Names on the Board...
Maybe anyone has the Same Board and could offer me the required files ?
i can`t seem to find them.
Thanks
Matthias
Reply 1 of 12, by flupke11
https://www.scrigroup.com/limba/engleza/87/PV … ide-Ha23264.php
That's the first hit when googling P6VBX7. I suppose it's that one out of the three, as the V must stand for VIA?
Looking somewhat further, a russian site hosted a .bin file: see here https://forum.ixbt.com/topic.cgi?id=4:30142. The site is down, though.
Bottom line, only PPGA support as far as I can tell.
Reply 2 of 12, by Horun
I found this but Wayback did not archive the .bin files:
https://web.archive.org/web/20010124040100/ht … p6vbx7tools.htm
Reply 3 of 12, by PC Hoarder Patrol
This file...
http://www.givemefile.co.uk/drivers/mainboard … file/15305.html
...appears to be the later B revision with additional processor support, and although it shows the Polaris brand, the bios id (2A6LGSHG) shows as Luckytech on Wims Bios (Luckytech Technology (SYE) VIA Apollo Pro Plus (692/ 2A6LGSHG)
https://www.wimsbios.com/biosupdates/luckytech.jsp
Reply 4 of 12, by Horun
PC Hoarder Patrol wrote on 2020-04-08, 00:10:
This file... […]
This file...
Nice find ! Should add it and the jumpers to the vogons archive..
Reply 5 of 12, by matze79
Yeah this BIOS does not work at all, i tried to patch it with rom.by,
but i can`t seem to get further then this:
123.98 KiB
GPL-2.0-or-later
VIA C3 and Coppermine Celeron are the only both CPU that will get to this point.
Seems i`m stuck to Mendocino, what a shame 100Mhz Bus and you can`t use it.
Reply 6 of 12, by matze79
http://krick.3feetunder.com/370mod/
Maybe this will work ?
Why it does not get past drive detection hmm
Reply 7 of 12, by matze79
I will try to source a Celeron 300 PPGA and clock it to 100Mhz FSB 😉
Reply 8 of 12, by flupke11
I remember a huge boost when I upgraded my Asus P2L97-A from a P2-233 to a PPGA Slocket Celeron 533.
These Celerons are not bad at all at those clocks, but all depends what you wish to do with it. I will not run Crysis 😀
Reply 9 of 12, by evasive
fwiw, this board now has a UH19 page:
https://theretroweb.com/motherboards/s/lucky-tech-p6vbx7
If you still own it, pictures of front and back would be welcome. The elusive B revision of the bios is included btw
Reply 10 of 12, by AlexZ
matze79 wrote on 2020-04-10, 08:40:
No need to go for Celeron 300. Mendocino Celeron 333-366 may work at 100Mhz FSB as well as the limit of manufacturing process was about 550Mhz. Just make sure to buy them in bulk. I have about 20 of these of various speeds except for 466-533 which are worthless as multiplier is way too high. They are fastest CPUs if your board doesn't support lower voltage than 1.8V.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 11 of 12, by Tetrium
matze79 wrote on 2020-04-08, 11:02:
Yeah this BIOS does not work at all, i tried to patch it with rom.by, […]
For what it's worth, the VIA C3 can utilize the 100MHz FSB.
Btw, you have any idea which exact C3 chips are actually supported by your board?
AlexZ wrote on 2021-10-01, 16:09:
Even if he had wanted to, his board is a s370 board and s370 Mendocino started at 333MHz. 300MHz Mendocino is Slot 1 only. Would be interesting to see if someone would be crazy enough to build a Slot1 2 s370 Adapter though 🤣
So I edited this before I first posted this because I wanted to check first and apparently there was a PPGA Mendocino 300MHz part! I always thought the 333MHz Mendocino was always the slowest for s370. Kinda a shame I don't have one but oh well.
I'd still want to see someone crazy make a Slot 1 to s370 adapter though 😜
My retro rigs (old topic)
Report spammers here!
Reply 12 of 12, by Repo Man11
Years ago I had a Via chipset Socket 370 AT board that worked with a Tualatin Celeron when combined with a Lin Lin socket adapter. This was in 2005/2006 when said adapter was still available at a very reasonable price, something that's unfortunately no longer the case. That was the fastest AT computer I've ever had.
