First post, by weldum
hi, i have a jetway 625emp800, that has a via c3 samuel2 800mhz processor soldered in
the problem is overheating, the motherboard works okay but at times it would freeze, i've tried changing the thermal grease to no avail (a white, cheap one)
what else to consider?
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 2, by Horun
weldum wrote on 2020-04-08, 02:15:
Is the fan on the heatsink working properly ? If possible set fan to highest speed in BIOS and do not let Windows control it thru APM.
Reply 2 of 2, by weldum
i think the fan is always running at max speed
is a standard fan that sits on top of the heatsink, if i connect it to the cha_fan connector it spins the same speed
anyway in bios there are no options for adjusting the fan speed
