First post, by 386SX
Hi,
I'd like to play these games with a modern Windows 8.1 32bit os in a problematic config (GMA3600 SGX545 integrated gpu.....) but both games seems to not start. While the gpu and its drivers were really a problem with anything but Win7 and even with that it was not the best config, are those games running on a modern machine or it's a problem of this config? Have you played them on modern os?
Also both 3dmark03 and 3dmark05 are hanging in the start logo but this I'm quite sure it's a driver/os/gpu combination problem and still trying to launch them but still can't while both should run. Have you ever had problems with those bench with other configs?
Thank
Reply 2 of 3, by Jorpho
386SX wrote on 2020-04-16, 07:44:
You know both of them are widely available on Steam and GOG, right? They're usually quite cheap, too.
