First post, by Intel486dx33
Here is an IBM thinkpad 380ED with original installation.
Still works great and the battery still holds a charge.
ThinkPad 380ED
Standard Features
CPU - Intel Pentium MMX 166 MHz CPU
Video - Neomagic MagicGraph128ZV with 1.125MB
12.1" FRSTN display with 800x600 resolution
12.1" TFT display with 800x600 resolution
RAM - 16MB memory standard (fixed internal) up to 80MB (1 SO-DIMM Socket) 48mb. Total installed.
Harddrive - 2.1gb , 3.0gb or 5.1gb HDD
Audio - CS4236B Audio controller
Floppy - 1.44MB FDD (non-removable)
CD-ROM 4x drive (non-removable)
Inferred - IrDA 1.1
(2) Type II, or (1) Type III PCMCIA slot
Win95
Info:
http://www-01.ibm.com/common/ssi/ShowDoc.wss? … quest_locale=en
Drivers:
https://thinkpads.com/support/Thinkpad-Driver … t/ddfm/380.html
IBM thinkpad 380 promotional ad Video:
https://youtu.be/N0zHan7E7Ps
Original install recovery CD link:
https://archive.org/details/thinkpad380rec
Reply 1 of 12, by Intel486dx33
I was able to pick up some additional hard drive for cheap.
I can use these build a DOS computer.
Reply 2 of 12, by Intel486dx33
Upgrades,
5gb IBM hard drive
32mb of ram for a total of 46mb.
3com PCMCIA Ethernet card.
Red pointer replacement.
Reply 3 of 12, by Intel486dx33
I have some new Win-95 software.
Reply 5 of 12, by Intel486dx33
This is the Best Retro Laptop ever
Love the BIG Key Keyboard..
Reply 6 of 12, by Hezus
No-one has replied to this wonderful little laptop in 2 years?
It still resembles the modern thinkpads so much. That black with the red accents.. instantly recognisable.
Are there any other upgrades you can make to it? Can you upgrade the CPU to a 233MMX?
Visit my YT Channel!
Reply 7 of 12, by Donovan V.
Ah... I used to have the 380XD and i loved every second of it. I have a soft spot for certain IBM's. The last one I bought is a Thinkpad t420s and the reason why I didnt go with the t430 was precisely the keyboard. As far as I am concerned no other brand comes even close to the pleasure that is using those keyboards and the 430 uses kinda chiclet keys which I really dont like.
Sadly mine does not have a socketed CPU so I am stuck with an i5 2520m because I do own a i7 but I cant switch it. :sadface: Anywhoo... loved that laptop too.
On a separate note. If you search ebay for MMC-1 you might find a much needed processor upgrade.
https://www.ebay.com/sch/i.html?_from=R40&_tr … =MMC-1&_sacat=0
I dont know if that laptop supports the microcode needed for the pentium II but... hopefully it does. 😁
Reply 8 of 12, by BitWrangler
I'm unsure if they have the same motherboard in the 380s vs the Pentium II class 385 and above, the modules look similar. I have heard of Tillamook modules being interchangable with low end PII in some laptops, but not sure about this one in particular.
Reply 9 of 12, by Donovan V.
BitWrangler wrote on 2022-04-01, 18:20:
I dont know either. But the processors ARE cheap so having one of those, even if it doesnt work cant hurt your budget much. I think they may be, since the northbridge is in the package but bios support might be an issue. Power delivery may also be something to consider. Best that can happen is that it simply works. Worst that can happen is that the whole thing burns down to a pile of ash because it wasnt compatible. 🤣 Nah, kidding. Sadly there arent any tillamooks available for that laptop RN.
Reply 10 of 12, by H3nrik V!
Donovan V. wrote on 2022-04-01, 20:19:
Well, there might be a risk of something else being damaged ... I'm not sure I'd dare taking that risk ...
Reply 11 of 12, by Intel486dx33
One of the Best Laptops of 1997
This Laptop had the Best TV commercial. They don’t make laptop commercials like this anymore.
On a Color CRT TV with 720p in 1997
Video link:
https://youtu.be/N0zHan7E7Ps?si=bRt2Y3tDvHdsCzIh
    24.8 KiB
    142.83 KiB
    557.54 KiB
    88.4 KiB
    IBM-380ED.rar
    2.68 MiB
    10 downloads
    IBM Spec sheets and Docs
Reply 12 of 12, by Intel486dx33
I have an upgrade.
Two 64mb RAM Sticks.
One for each of my 380 laptops.
In 1995 64mb in a laptop was Very Expensive and Unthinkable.
Even in 1997 it was very expensive for a Desktop an NOT common.
8mb and 16mb of RAM was more common in computers before 1998.
    879.65 KiB
