First post, by kolderman
I am trying to get MI1 Ult Talkie working on a DOS PC. I have tried several soundcards from ESS audiodrives, to a CT1600 and CT1740.
They all have the same problem -- when digital speech starts, it works for a few seconds, then the whole PC freezes up.
On a different PC with an Audician32 it is fine.
The PC is running DOS6, MMX233 slowed down as much as possible with setmul. Other games like DOOM work fine, but are not playing back speech obviously. This is the only game that has an issue, and only during speech. Intro music is fine, and it gets all the way to the first pirate conversation in the pub before it freezes.
Using standing 220/5/1 settings across all cards.
Any ideas?
Reply 1 of 9, by keropi
what mouse driver are you using? I had the same freezing issues in both Ultimate Talkie and Space Quest 4 talkie games and in the end it was because of the mouse driver I was using: for me CTMOUSE v2.0a4 worked fine - but it depends on the hardware implementation on the mobo so maybe an earlier version is better or something else entirely
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 9, by kolderman
Ctmouse and pmouse. I will try no mouse and see what happens, thanks.
Reply 3 of 9, by kolderman
keropi wrote on 2020-04-23, 07:49:
Looks like mouse driver was it. I was using CTMOUSE 1.9.1. Removing it entirely and using keyboard worked fine with the CT1740, no crashing. I should have mentioned it worked with the audician32 but that was under Win98. I guess I will try the newer version of CTMOUSE...are there any other good mouse drivers worth trying as well?
Reply 4 of 9, by keropi
Then maybe you'll be just fine with CTMOUSE 2.0a4 as well - I was using 1.9.1 and had freezes. They use different methods to initialize the mouse so if one does not work try the other. I also remember I had the same issue with microsoft's driver... you just have to experiment .
did you also try CPMOUSE? Re: CuteMouse not working properly
Reply 5 of 9, by kolderman
I looked at CPMOUSE but it appears to only support serial mice on COM port, not PS/2. I am going to try 2.04a soon.
Reply 6 of 9, by kolderman
keropi wrote on 2020-04-23, 08:20:
So I saw there was a 2.1b too, so I thought I would try it, but same problem. Then went back to 2.0a4, and it works! Thanks Keropi 😀
Reply 7 of 9, by keropi
Awesome! It is my understanding that 2.1 is meant for newer systems - p4 and above or something.
Glad you got it working!
Reply 8 of 9, by jameswhite1979
Also confirming that with talkie ~Indy and Monkey2 I was getting freezing and was using an older CTmouse then read this and grabbed 2.1B and same issue then used 2.0a4 and it fixed it
Reply 9 of 9, by amontre
Mine was the opposite, 2.0a4 freezes but 1.9 works
#1 NEC Pentium 133 | 64mb RAM | 40gb HDD | s3 Virge DX | Voodoo 2 | SB AWE64 Gold
#2 NEC 486DX2 66 | 16mb RAM | 40gb HDD | SB AWE64 Gold
#3 Acer 386 SX 33 | 8mb RAM | 20gb HDD | PicoMEM + Adlib
# Amiga 1200 | MSX2+ | Roland MT-32 | SC 55MkII | YAMAHA MU80
