First post, by khyypio
I´m refurbishing an XP machine for a friend of mine and I´m replacing the old hard disk with SSD. I have the old product key on the side of the computer but my friend doesn´t know what happened to the installation CD, or if he ever even had one to begin with. For what I could find out, it´s legal to download an ISO file and use the original product key with it. I just don´t know where to download one. Any help? I should use the latest Service Pack, right?
Reply 1 of 7, by jesolo
Unfortunately, Microsoft never made these available for download to consumers.
Your best option is to just download it from someplace else - archive.org might have some copies.
Reply 2 of 7, by gdjacobs
jesolo wrote on 2020-04-28, 14:33:
I believe they're available through MSDN.
Reply 3 of 7, by khyypio
gdjacobs wrote on 2020-04-28, 14:55:
I found this: LINK REMOVED
I can´t tell which is retail in which is OEM, or does it make a difference for the product key? What does "x86" mean?
Reply 5 of 7, by Falcosoft
khyypio wrote on 2020-04-28, 15:47:
x86 means the 32-bit version of the OS
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 6 of 7, by khyypio
OK, thanks.
Reply 7 of 7, by BEEN_Nath_58
khyypio wrote on 2020-04-28, 17:42:
OK, thanks.
You can search on the internet for your OEM copy, if you use the disc of some other companies like Dell, Gateway. They might have different CD-Keys. Or if you use a MS OEM disc, download that one. You can google search first then move to archive.org
