First post, by muon
Hi! These days I'm trying the OS/2 1.3 operating system and I found a problem. I read that operating system has support for SCSI CDROM (I have a Toshiba SD M1401) and I would like to test . For the test, I took a 486 class machine and that SCSI CDROM in a adaptec 1542 SCSI controller.
I never get to read a CDROM disk!!
The scsi controller is recognized for the OS/2. The CDROM too: in the system appears the D unit (CDROM letter) But I insert a CDROM disk with files and I haven't get any file. I thought the CDROM is defective (it's very older unit), but I take my install disk for W98 and I boot the computer with that disk and I select CD-Support and the CDROM disk works properly.
The CD ROM disks that I test are in old compatible format ( names 8.3, ISO 9660...). If I inser CD - Audio I can play that CD whiout any problems in Os/2
Any suggestions?
This is a copy the config.sys and autoexec.bat
PROTSHELL=C:\OS2\PMSHELL.EXE C:\OS2\OS2.INI C:\OS2\OS2SYS.INI C:\OS2\CMD.EXE
SET COMSPEC=C:\OS2\CMD.EXE
LIBPATH=C:\OS2\DLL;C:\OS2\SUPPORT;C:\;
SET PATH=C:\OS2;C:\OS2\SYSTEM;C:\OS2\INSTALL;C:\OS2\SUPPORT;C:\;
SET DPATH=C:\OS2;C:\OS2\SYSTEM;C:\OS2\INSTALL;C:\;
SET PROMPT=$i[$p]
SET HELP=C:\OS2\HELP
BUFFERS=30
DISKCACHE=64
MAXWAIT=3
MEMMAN=SWAP,MOVE,SWAPDOS
PROTECTONLY=NO
SWAPPATH=C:\OS2\SYSTEM 512
THREADS=128
COUNTRY=001,C:\OS2\SYSTEM\COUNTRY.SYS
DEVINFO=SCR,VGA,C:\OS2\VIOTBL.DCP
SET VIDEO_DEVICES=VIO_IBMVGA
SET VIO_IBMVGA=DEVICE(BVHVGA)
DEVICE=C:\OS2\POINTDD.SYS
DEVICE=C:\OS2\MSSER01.SYS MODEL=199
DEVICE=C:\OS2\MOUSE.SYS TYPE=MSSER$
DEVICE=C:\OS2\PMDD.SYS
SET KEYS=ON
DEVICE=C:\OS2\SUPPORT\DENON.VSD
DEVICE=C:\OS2\SUPPORT\STDCDROM.VSD
DEVICE=C:\OS2\SUPPORT\CDROM.TSD
IFS=C:\OS2\SUPPORT\CDFS.IFS
RUN=C:\OS2\SUPPORT\LOGWRITE.EXE
SET BOOKSHELF=C:\OS2\BOOK
SHELL=C:\OS2\COMMAND.COM /P
BREAK=OFF
FCBS=16,8
RMSIZE=640
DEVICE=C:\OS2\EGA.SYS
DEVICE=C:\OS2\DOS.SYS
PATH C:\OS2;C:\OS2\SYSTEM
APPEND C:\OS2;C:\OS2\SYSTEM
SET COMSPEC=C:\OS2\COMMAND.COM
CALL HELP ON
COPY C:\OS2\COMMAND.COM C:\ >NUL
Thanks in advanced
