First post, by daemonjax
2.62.3 and older display correctly.
I get a 1 pixel wide vertical black line along the left side of the screen -- it's offset 1 pixel away from the left edge of the displayed screen (stretched, keep aspect ratio).
I only tested glide on d2:lod because that's all I use it for.
See screenshot (see bottom left of screen, where it's most noticeable): https://photos.app.goo.gl/jf6PiwgMA3HdMK21A
Reply 1 of 1, by Dege
Could you attach your config file plz?
I gave it a quick go with both D3D and Glide but couldn't see any difference between 2.62 and 2.63
