First post, by bttr
Hi!
I'm the proud owner of two 800CTs: One with a P100 and 16MB RAM, the other with P166MMX and 48MB RAM.
Recently I fiddled around with the OmniBook Support Utility Disk and found three tiny tools there: DOCK.COM, EXTFLOP.COM, and IDE.COM
DOCK.COM source code
CSEG
RS 100h
; --- Read status.
in al, 66h
; === Use bit 4 only as return code.
; --- Make bit 4 the lowest bit.
ror al, 1
ror al, 1
ror al, 1
ror al, 1
; --- Kill all the upper bits.
and al, 1
; --- Call DOS function "TERMINATE WITH RETURN CODE".
mov ah, 4Ch
int 21h
END
EXTFLOP.COM source code
CSEG
RS 100h
; --- Read status.
in al, 67h
; === Use bit 3 only as return code.
; --- Make bit 3 the lowest bit.
ror al, 1
ror al, 1
ror al, 1
and al, 1
mov ah, 4Ch
int 21h
END
IDE.COM source code
CSEG
RS 100h
; --- Read status.
in al, 67h
; === Use bit 2 only as return code.
; --- Make bit 2 the lowest bit.
ror al, 1
ror al, 1
and al, 1
mov ah, 4Ch
int 21h
END
Source code is for the R86 assembler, which is part of http://www.lsi-j.co.jp/freesoft/. Don't ask, I just like R86.
But this source code is easy to convert to NASM or even DEBUG.
Now my problem is, these tools don't work for me.
Whatever I try, ports 66h and 67h always return FFh. I also verified with DEBUG.
Okay, EXTFLOP.COM is never called from the Utility Disk, but DOCK.COM is.
(I didn't try IDE.COM, as it also reads the same status byte EXTFLOP.COM.)
What I already tried:
Setup                        | 66h | 67h
800/166 BIOS 2.01.00 gr | --- | ---
Boot from HDD | --- | ---
FDD not connected | FFh | FFh
FDD connected (hot-plug) | FFh | FFh
Boot from FDD | FFh | FFh
Boot from HDD (docked) | --- | ---
Boot from FDD (docked) | FFh | FFh
800/100 BIOS 2.00.00 en | --- | ---
Am I doing something wrong?
Would be nice, if some other people could try on their own machines.
OmniBooks 300, 425, 430, 530, 600, are probably worth to try own too.
