First post, by perhenden
A mystery motherboard has found it's way to my house!
Can you identify this Socket 7 motherboard?
I can't find the model and manufacturer of this Socket 7 motherboard, nor it's jumper settings documentation
On the back of the board, TGS 90200 REV B 960228 is printed.
It's using the Intel 430fx chipset, and an onboard Trident tgui9680 - 1 graphics chip.
It has a 60 pin SCSI header (EDIT: No, that's something else).
An Intel Pentium 100Mhz and EDO-ram came with the board.
There is a riser board (2 isa, 2 pci), and there is a cache expansion slot.
Picture attached.
Reply 1 of 18, by synrgy87
It's a TriGem board used in prebuilts like compaq or hp or olivetti, I can't provide much more information than that but maybe looking for socket 7 models or pentium models of oviletti(and others they supplied many OEMS) systems would help, if it boots it may have a useful bios id string, worth checking for.
Reply 2 of 18, by dionb
Not at all sure that 60p connector is for SCSI - for starters there don't seem to be any SCSI controller chips on the board, also 50p and 68p SCSI were a thing, 60p wasn't.
But jumper settings seem pretty well documented on the board - what are you trying to do that you're stuck with?
Reply 3 of 18, by perhenden
dionb wrote on 2020-05-07, 16:14:
That makes sense, I noticed a label saying SCSI somewhat close to the header, that's where my guess came from.
EDIT: the manual says it's for an audio expansion card.
Reply 4 of 18, by perhenden
I didn't see how to select frequency and multiplier for the CPU
Reply 5 of 18, by imi
the 60pin connector is probably for some proprietary add-on card
Reply 6 of 18, by evasive
For an audio board to be exact.
I must have those BA2284 settings somewhere.
Reply 7 of 18, by evasive
J7 J8 Bus speed
2-3 1-2 50
1-2 1-2 60
2-3 2-3 66
1-2 2-3 not documented
J1(BF1) J2(BF0) Multiplier
2-3 2-3 1.5x
2-3 1-2 2x
1-2 1-2 2.5x
1-2 2-3 3x
So if you have a Pentium 90, use 60MHz bus speed and 1.5x Multiplier
J10 CPU voltage
1-2 3.3V
2-3 3.5V
J11 AT bus clock
1-2 PCI clock /3
2-3 PCI clock /4
It seems the maximum this thing will take is a 166MHz Pentium, pay attention to the voltage setting.
Reply 8 of 18, by dionb
perhenden wrote on 2020-05-07, 19:37:
See above for the spoonfeed version, but in terms of background/how to figure this out yourself:
- BF0 and 1 are the So5 multiplier pins, you can read the encoding in Pentium datasheets if nowhere else.
- S0 and S1 are not as universal, but if it says CLK, that's your FSB. By setting a low (1.5x) multiplier, you can safely test what all four possible S0/S1 combinations do.
Reply 9 of 18, by perhenden
Thanks, that's really helpful! 😀
Reply 11 of 18, by evasive
Thank you, we will add it to the UH19 database. Could you please make a bios dump as well?
Reply 12 of 18, by charliegolf
I have an olivetti xana 53-120 and this is the motherboard that is in that. It takes up to 200 non mmx pentium. The big brown slot is for a riser that you need for expansion. Has built in s3 graphics. The funny connector behind the riser slot is for a proprietory soundblaster that came with it.
YouTube:
66Mhz Brain
Reply 13 of 18, by evasive
Thank you for that info, could you please make a bios dump so it can be added to the page-to-be-in UH19?
Reply 14 of 18, by charliegolf
I'll do a dump for the Olivetti
YouTube:
66Mhz Brain
Reply 15 of 18, by perhenden
I upgraded the bios, from 1.2x to version 1.30-0 (rom0130.zip), from https://www.driverguide.com/driver/detail.php?driverid=1125.
Unfortunately the new bios version has a very long delay during POST, before RAM test, because it takes super long to initialize the IDE-devices.
My backup bios cannot be found, or I'd submit and use that.
I've done a backup of this bios (attached). The motherboard works well with it, except the long POST time.
The sticker on the bios chip of this board says "Milano v1.13".
Charliegolf provided the bios from his olivetti xana 53-120, attached as bios_xana_53_120.zip.
Within this zip file there are two files. The file called bios was done using NSSI the file called unibios was done using uniflash.
In my case uniflash reported a checksum error when flashing the 'unibios' file and a size mismatch with the 'bios' file.
It's unsafe to reboot after this checksum error on write, best to reflash the backup instead, which worked well in my case.
Reply 16 of 18, by perhenden
evasive wrote on 2021-05-03, 07:32:
Ready now, @evasive.
Reply 18 of 18, by Station2381
perhenden wrote on 2021-05-23, 14:32:
I upgraded the bios, from 1.2x to version 1.30-0 (rom0130.zip), from https://www.driverguide.com/driver/detail.php?driverid=1125 […]
Hi. can i have a request for you please, thanks 😀
