I accidentally bought a PC Chips M919
First post, by boxpressed
So I thought I was buying another Socket 3 VLB/PCI board not unlike an excellent board I own with an SiS chipset. It is NOS and came with original box, manual, and cables.
I remember reading about 486 boards with fake cache but didn't put two and two together until the board arrived. It looks really nice, but I haven't had time to test it yet.
This one doesn't have any ICs in the corner of the board and comes with what does look like a 256KB cache memory module. Is it likely that this module is real? Were the only fake chips soldered to the board where the open spaces are?
The attachment IMG_9460.jpg is no longer available
The attachment IMG_9461.jpg is no longer available
The attachment IMG_9462.jpg is no longer available
Reply 1 of 31, by mpe
The only fakes I've seen are those soldered on the motherboard. Looks like your board doesn't have them (upper right corner, next to SIMM).
The module looks genuine to me.
If you have it you can easily confirm it by running cachechk, speedsys or a similar tool.
Blog|NexGen 586|S4
Reply 2 of 31, by Horun
The fake cache boards were soldered cache. Being that is a COAST it should be real. One thing: It says 3v so you must use a 3.3v 486, not a 5v as the cache is powered off the cpu VRMS and at 5v you would burn up the cache chips over time --- Unless they are 5v tolerant.
Here is a topic here at Vogons about those coast modules: Re: Lets make new M919 Cache sticks?
edit: I type to slow 🤣
Reply 3 of 31, by boxpressed
Thanks. Glad to know that the modules didn't have fake chips on it. Will probably be able to test tomorrow.
I think this board is actually an Amptron DX-9700, which would explain the sticker on the back of the module.
The box also has a logo that's a big "A."
Reply 4 of 31, by boxpressed
Horun wrote on 2020-05-07, 23:25:
Good to know! Glad I haven't fired it up yet.
Reply 5 of 31, by SETBLASTER
how much did you pay for it, that cache module alone must be worth like 100 bucks now
Reply 6 of 31, by Horun
SETBLASTER wrote on 2020-05-08, 01:40:
I was thinking something like that myself earlier as a real working coast for a DX9700 in USA is as much as a bare board without one...if you can find just the coast.
Reply 7 of 31, by boxpressed
I paid about $75 shipped for everything.
Reply 8 of 31, by nuno14272
This is so strange..
We can see clearly the onboard cache running in circles going nowhere... but this board as them and, a cost module... so. i'm thinking. This version as the cost modlue and not the soldered chips. but, there where others, with the fake cache chips and the cost module not soldered !!!
really confusing this board
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 9 of 31, by imi
those traces do have a certain beauty though, I'll give them that ^^
Reply 10 of 31, by kixs
There are many revisions of M919 board. This one is V3.4B/F and it's the last one. It never had soldered cache chips just the COAST module. So you either have cache via COST module or you don't have it at all. Performance penalty with 16KB L1 486 chips is not that big, but it is still noticeable.
Since you probably got the board as-is, the price is fair.
Reply 11 of 31, by boxpressed
About ready to test this thing, but I need some help with memory. I have a bag of mismatched 72-pin SIMMs and have always been bad at deciphering the markings on the chip to determine their size.
I sorted them by type (FPM or EDO), speed, and whether there were chips on both sides. I ended up with two sets, one FPM and one EDO (I think). Can anyone tell me the size of these SIMMs (how many megabytes)?
FPM
The attachment IMG_9466.jpg is no longer available
EDO
The attachment IMG_9465.jpg is no longer available
I'm leaning toward trying the FPM set first. I assume that if the sizes of the sticks are different, it won't be a problem. I am going to use an Intel 486DX4-100 and have set the jumpers for a 3.3V CPU.
Reply 12 of 31, by SETBLASTER
no clue on how to read memory specs and count that specification of the chip and multiply by #of chips on the memory to get the total amount of memory on 1 stick. if anyone can explain in detail i would really appreciate in order to learn.
Reply 13 of 31, by Horun
The km44c1000cj-6 chips in top pic should be 1Mx4, 60nS FPM. 8 chips = 4Mb SIMMS (8x1Mx4 /8), if double sided would be 8Mb SIMMS.
The gm71c17403cj6 chips in bottom pic should be 4M x 4bit 60nS EDO. 8 chips = 16Mb SIMMS or 32MB if double sided
SETBLASTER wrote on 2020-05-09, 03:52:
Added: All ram is measured in Bytes (8bits=1Byte) no matter if 16bit (30pin), 32bit (72pin) or 64bit (DDR, etc) so in above the km44c1000cj chips are 1M x 4Bit chips. So two would equal 1M x 8bit (or 1M Byte) so if 8 then 4Mbyte. The real quirk is finding datasheets to tell you what each chip is..
Reply 14 of 31, by boxpressed
Horun wrote on 2020-05-09, 04:53:
Thank you! I look at the datasheets but then get confused. I think I understand now. These are double sided.
I also found these, which thankfully, are marked as 8MB EDO SIMMS (double sided). These chips are 1Mx16, so four chips per SIMM would be 64 Mb or 8 MB.
The attachment IMG_9468.jpg is no longer available
Reply 15 of 31, by Horun
Yep ! Some older boards do not like the high density chips in your example, is why you see a lot of 8 chips per side versus 2 chip per side 72pin SIMMS for 486. Most Pentium boards are ok with the high density but many 486 do not like them. You can try them but if you get a mem error (beeps on the speaker) that is usually why,
Reply 16 of 31, by boxpressed
I'm going to stick this heatsink/fan combo onto the 486DX4. The fan has a two-pin power connector. Ideally, I'd like to use a 2-pin to Molex adapter, but I don't have one of those.
The attachment IMG_9470.jpg is no longer available
The M919 does have a fan connector. I'm sorry if this is an obvious question, but connecting the fan is as simple as plugging in the fan header where the red wire is "12V" and the black wire is "G," correct? Just don't want to blow anything up at this point.
The attachment IMG_9469.jpg is no longer available
Reply 17 of 31, by chrismeyer6
It should be that simple. You can always verify voltage at the pins with a multimeter.
Reply 18 of 31, by boxpressed
chrismeyer6 wrote on 2020-05-09, 15:11:
Thank you for the quick reply. I figured why risk it when someone else might confirm soon.
