First post, by 386SX
Hi,
I was thinking to buy a retail version of one of the two software for a Win ME machine using video cards from 1998 to 2005 more or less so to benefit of the old fashion gpu only acceleration and not all the fake hd cpu software filters and similar things of the absurdly heavy modern players.
I was thinking to something like PowerDVD XP 4 or WinDVD Platinum 5. What version would you suggest and which video cards? I know which model have motion compensation only and or IDCT but I want your opinion into this. I've seen that the demo of the Windvd Platinum support IDCT of the ATi old cards and quality is incredible excellent with DVI output much better than any home dvd player I've tried (modern fixed resolution like 720p, 1080i etc and upscaling is awful imho).
Thanks
Reply 1 of 10, by Stretch
I had the first several generation of Ati Radeon video cards, and they included MMC/DVD player on the driver CD, which should provide IDCT.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 2 of 10, by 386SX
Stretch wrote on 2020-05-09, 15:54:
Unfortunately all the cards I bought in the past came without boxes/cd and I read the ATi (I think based on Cinemaster engine) DVD Player need the exact cd with the right card something like that. Surely it'd be the best combination, it'd interesting to compare it to modern GPU decoding quality if anyone can with no post-processing.
Reply 3 of 10, by Standard Def Steve
I can highly recommend PowerDVD XP/4.0 along with any Radeon video card for older systems. It even allows a weak P2-300 or K6-2 500 to play DVD smoothly. Here were some CPU usage numbers I saw whilst playing DVD on the following systems, all with PDVD 4.0:
K6-2 500MHz, Radeon 7000, 128MB SDRAM, Win2000 SP4: 68 - 98%
P2-300, Radeon 7000, 512MB SDRAM, Win2000 SP4: 47 - 78%
PIII-550 (Katmai), Radeon 7000, 512MB SDRAM, Win2000 SP4: 29 - 40%
PIII-S @ 1628MHz, Radeon 9800 Pro, 2GB DDR-SDRAM, WinXP SP3: 2 - 4%
"A little sign-in here, a touch of WiFi there..."
Reply 4 of 10, by swaaye
I prefer Cinemaster 99 for K6-2/3 level hardware. I even had a P3 at 300MHz decoding in software with it. Excellent quality too. It can be found with some searching. This is what the ATI player is based on.
Once you go into somewhat faster hardware like a midrange P3, there is an old version of Klite Codec Pack that works with Win98 and has a PowerDVD MPEG2 decoder that works very well.
Reply 5 of 10, by 386SX
Standard Def Steve wrote on 2020-05-09, 16:47:
I can highly recommend PowerDVD XP/4.0 along with any Radeon video card for older systems. It even allows a weak P2-300 or K6-2 […]
Thanks. I tried both PowerDVD XP and Windvd 5. Interestingly with Win ME I've seen a P3-500 with the Radeon 9250 using from 2 to 10% of cpu (with IDCT). That's one of the things that lately is interesting me, how good these old fashion acceleration resulted in visual quality compared to both home players and modern GPU VDPAU or whatever acceleration. The REALMagic cards were awesome but had their problems with the external vga cable and general stability that depends on many variables (video card first, cables second, monitor also..), but I forgot at some point how good the early 2000-2003 DVD decoding status was.
Nowdays everyone seems focusing on blue-ray and ultra high resolution stuff but what's the point there where pixel resolution is that high.
I had the feeling that Windvd had better visual quality (?).
Reply 6 of 10, by 386SX
swaaye wrote on 2020-05-09, 17:07:
Yeah I remember also how good ATi players, probably deeply optimized for its hardware, were on a friend Rage 128 card in its days. How did ATi dvd sw worked? Did it need the exact card of the box or just the model?
Reply 7 of 10, by swaaye
386SX wrote on 2020-05-09, 18:12:
As I said, the ATI player is an OEM version of Software Cinemaster.
http://www.pennskog.com/cinemaster/software.htm
I dug up some product info. It appears to support all of the important hardware acceleration and CPU SIMD features.
https://web.archive.org/web/20010124062500/ht … tore/cmdvd.html
Rage 128 has acceleration for almost all of the MPEG2 decoding process so you can play DVDs on a very slow system with it.
Reply 8 of 10, by Carrera
Back in the day I could only get smooth playback using WinDVD and DVDgenie (what versions I don't recall).
There was a setting in DVDgenie to crank the "quality" of playback way down and then everything was smooth.
I am not sure of the system I had at the time. Maybe a K6-III+ or even an Athlon with whatever the fastest and mostest RAM is my board and OS could handle (likely 4 GB).
I was running win98SE for sure though.
Reply 9 of 10, by Jo22
I also started with PowerDVD XP (WinDVD never worked for me, not sure why)..
However, I quickly updated and bought myself a copy of PowerDVD 6 Deluxe (released ca. 'o4 or' 06).
That version served me well into the 2010s and had awesome deinterlacers built-in (could also use the GPU's deinterlacing via DXVA).
If memory serves, that one was the last version to run on Windows 98SE/Me.
Version 7 was intertesting, because it initially supported DVD, HD-DVD and Blu-Ray.
Later versions switched to a different code base, I assume, and had little in common to the classic releases.
Anyway, I wouldn't use anything below PowerDVD 3, since it lacks advanced CPU support (3D Now ?, SSE2, SSE3 etc.)
Edit: I forgot. PowerDVD 3 to 6 also worked for me with an -ahem- RC0 DVD drive. And from inside of a VM.
This information might be interesting for some of you, I guess. 😀
Reply 10 of 10, by 386SX
In WinDVD Trial 4 Platinum there's the check info for all three version of 3DNow!, SSE1, 2 and even HyperThreading I wasn't expecting. The good thing of WinDVD is that it actually says in the info if you're using IDCT acceleration or other. In PowerDVD XP I did see the "ATI hardware decoding: in use" or something like that but imho I always had the feelings the quality of the final image was a bit different but probably just feelings. But PowerDVD felt having faster window management from desktop to full screen or for resize it.
