First post, by 386SX
Hi,
which is the oldest video card/gpu with Win9x/ME support having DVI and possibly supporting the 1280x768 resolution?
I'd imagine some Geforce 2 model, the G550 and some early Radeon models?
Thank
Hi,
Thank
I think I saw once on ebay a TNT2 from ASUS with a DVI port. I was tempted to buy it but then I didn't need it and let it go. This was a couple of months ago... I'll see if I can still find a link.
edit: found another one!
I hope mods don't mind sharing this ebay link:
https://www.ebay.it/itm/ASUS-AGP-V3800-16M-Nv … dIAAOSw1nVeJ1Sj
However it can be found under the name ASUS V3800M. Cheers!
There was an add-on for the Matrox Millennium G200 what provided a DVI port.
Old discussion on this: Re: Legacy PCI graphics card with DVI
Eta: links:
https://multi-com.stores.yahoo.net/comg2dvidmod.html
https://commons.wikimedia.org/wiki/File:Matro … _Flat_Panel.jpg
Is this too much voodoo?
there's some early ATi Rage cards that have DVI, but seeing as DVI was introduced in 1999 you'll probably not find anything older ^^
A Rage128 Pro variant had DVI .
https://commons.m.wikimedia.org/wiki/File:BBA … 128_Pro_DVI.png
imi wrote on 2020-05-10, 13:15:there's some early ATi Rage cards that have DVI, but seeing as DVI was introduced in 1999 you'll probably not find anything older ^^
VESA DFP came before and was based on PanelLink. Apparently, DVI cards can work with DFP monitors using a passive adapter. Reverse may or may not work .
the VESA DFP was also introduced in 1999 though and didn't get any widespread adoption
The ATI Expert LCD is Rage LT based, but I do not know the release date . I assumed it predated 1999, but I really do not know .
This isn't exactly related, but I have a geforce 4 card that only has 2 DVI connectors and no VGA at all. I was just wondering if there are earlier cards that dropped VGA connector and have only DVI connectors? I am using the card with DVI to VGA adapter, but I am unsure if the adapter reduces the image quality.
Thanks for the answers. I wasn't expecting a Rage and G200 card having DVI support! Incredible. Also I imagine the G200 with that DVD decoder module with DVI output would be a great combination! 😀
What about the Millennium and Mystique black connector? Was it a digital connection?
Baoran wrote on 2020-05-10, 15:07:I am using the card with DVI to VGA adapter, but I am unsure if the adapter reduces the image quality.
Generally, DVI-to-VGA adatpers are completely passive devices: the card already generates an analog VGA signal and the adapter just connects the relevant pins.
https://en.wikipedia.org/wiki/Digital_Visual_ … rface#Connector
Conceivably, a card which has a DVI connector instead of a VGA connector could have additional circuitry that could degrade the signal – but that seems very unlikely.
Jorpho wrote on 2020-05-10, 17:04:Generally, DVI-to-VGA adatpers are completely passive devices: the card already generates an analog VGA signal and the adapter j […]
https://en.wikipedia.org/wiki/Digital_Visual_ … rface#ConnectorConceivably, a card which has a DVI connector instead of a VGA connector could have additional circuitry that could degrade the signal – but that seems very unlikely.
I imagine it depends on the adapter quality. Maybe the native DAC filters on the video card may result in a better quality as we can see the old differences between Matrox cards and the others for the VGA output, so maybe in the adapter a better design may improve or other way degrade the final quality.
as long as the contacts on the adapter aren't corroded or anything there should be no loss in quality... could just use a DVI-I to VGA cable if you are that concerned :p
the DVI-I connector carries the same signal a VGA connector would, it just has more pins for digital as well, so there is no loss compared to VGA just because of the connector used.
You can buy an active VGA to dvi adapter or active VGA to HDMI and then use an HDMI to dvi cable. That would let any card support dvi even from the earliest VGA cards.
candle_86 wrote on 2020-05-11, 03:50:You can buy an active VGA to dvi adapter or active VGA to HDMI and then use an HDMI to dvi cable. That would let any card support dvi even from the earliest VGA cards.
And the resulting quality would be horrid for certain resolutions since they would have to be scaled.
cyclone3d wrote on 2020-05-11, 06:03:candle_86 wrote on 2020-05-11, 03:50:You can buy an active VGA to dvi adapter or active VGA to HDMI and then use an HDMI to dvi cable. That would let any card support dvi even from the earliest VGA cards.
not if you get quality active adapters, dont buy the crap they sell at walmart or best buy, a good quality active adapter should cost around $60, and have proper hardware to convert the analog to digital signal without quality loss. The quality issues are with cheap adapters for 20 bucks
I have an IBM OEM Number Nine-made S3 Savage 4 Xtreme with DVI from late 1999 - here's a stock pic of the card:
The production card has a heatsink of course. I believe IBM shipped them in systems sold with CRT monitor with DVI-A connector.
dionb wrote on 2020-05-11, 14:47:I have an IBM OEM Number Nine-made S3 Savage 4 Xtreme with DVI from late 1999 - here's a stock pic of the card:
You'll not believe this but I found that card today (:D) exactly like that with heatsink, different brand rams, different type of capacitors, same bios number but the latest above. 😀
I'll test it later. Also a Radeon 7000 (RV100) I didn't remember having the DVI already.
candle_86 wrote on 2020-05-11, 13:40:cyclone3d wrote on 2020-05-11, 06:03:candle_86 wrote on 2020-05-11, 03:50:You can buy an active VGA to dvi adapter or active VGA to HDMI and then use an HDMI to dvi cable. That would let any card support dvi even from the earliest VGA cards.
But what happens when DVI or HDMI doesn't support the resolutions and /or refresh rates of VGA.. and what about the LCD monitors supporting those resolutions / refresh rates?
At the very least you are going to get some aspect ratio / screen stretch / blurring unless you have an active converter that does letterboxing and runs the screen at the native resolution.
If it doesn't run at native resolution, then you are going to get blur due to scaling.
If it does run at native resolution, then you get tiny images on the screen.... running say 320x240 on a 1080p screen with the screen at native resolution gives you a tiny box.
I do have a fully configurable TVOne VGA scaler that allows me to configure absolutely everything. But that still won't fix some stuff from my understanding. I haven't actually tried it with my freesync monitor though... not sure I have the adapters needed to convert everything sufficiently though I think I might.
What I would like to see is a fully configurable converter that supports free-sync/G-sync so we can get those higher refresh rates back... but I doubt one will ever get made.
See here for another discussion on 70Hz output:
https://www.vogons.org/viewtopic.php?t=68506
cyclone3d wrote on 2020-05-11, 17:33:But what happens when DVI or HDMI doesn't support the resolutions and /or refresh rates of VGA.. and what about the LCD monitors […]
candle_86 wrote on 2020-05-11, 13:40:cyclone3d wrote on 2020-05-11, 06:03:And the resulting quality would be horrid for certain resolutions since they would have to be scaled.
If it does run at native resolution, then you get tiny images on the screen.... running say 320x240 on a 1080p screen with the screen at native resolution gives you a tiny box.I do have a fully configurable TVOne VGA scaler that allows me to configure absolutely everything. But that still won't fix some stuff from my understanding. I haven't actually tried it with my freesync monitor though... not sure I have the adapters needed to convert everything sufficiently though I think I might.
What about this slightly shady looking thing ?
https://m.alibaba.com/product/60439619877/FHD … g_140x140xz.jpg
EDIT: Would require an EDP to Displayport adapter and no guarantes as to whether 70Hz VGA input would do .
