First post, by zapbuzz
I'm getting this card i remember it used to be around but i haven't seen it anywhere for many years I wanted to see if anyone had some input about them.
I have to refurb it as fan is broken but if I can get some input what its been used on what games work alright etc.
Heres a photo of it
wondering if it'd run on windows 9x
    150.97 KiB
Reply 4 of 9, by pentiumspeed
Ah, dead fan.. I had fan die (spinning perfectly for several seconds then slow down then stopped), every time computer turned on. Was HD3650 by sapphire bought couple since new and still have them. Rebuilt using a notebook fan in place of original to keep one slot design, had to cut away part of the plastic housing where fan used to be.
Cheers,
Great Northern aka Canada.
Reply 5 of 9, by zapbuzz
darry wrote on 2020-05-11, 00:49:
zapbuzz wrote on 2020-05-11, 00:25:
darry wrote on 2020-05-10, 22:57:
Nope . Nothing after the X800 seies does .
you think it'd run on 2000?
Yes
Thanks but you know i'll try to anyway 😀 i will post the result
Reply 6 of 9, by zapbuzz
pentiumspeed wrote on 2020-05-11, 21:02:
Cheers,
maybe its bearing just needed lube?
Reply 7 of 9, by pentiumspeed
To your response, yes, if the fan is sticky, or rattling noisily even not spinning freely when fingers spun quickly to test and watch it spin to stop. Use oil only.
On mine:
I did check the fan's bearing freedom by fingers flick and fan spun freely and magnetic wiggled to stop. Rarely see a fan die. But this one unusual, failed few seconds after turn on every time.
Cheers,
Reply 8 of 9, by zapbuzz
pentiumspeed wrote on 2020-05-12, 23:45:
To your response, yes, if the fan is sticky, or rattling noisily even not spinning freely when fingers spun quickly to test and […]
On mine:
Cheers,
yes its rare but the way a lot of these fans are mounted on heat sinks these days its almost like its deliberate. I mean mounting the fans bearing housing right on a heat sink that the bearing housing cannot vent. Plastic is like a heat insulator.
Reply 9 of 9, by zapbuzz
It was disappointing to see bulging capacitors on this card guess it'll need to be recapped AS well as getting a new fan. Wow if it were like that in the photo Above i'd have moved onto another one. (well, i knew i shouldn't have but with HDMI I had to have it)
