First post, by candle_86
So I've finally got a socket 423 setup, right now heatsink is zip tied down which works for now but I noticed the case has mounts for standoffs that lineup with the Intel 850 board for the original heatsink design. I also noticed socket 604 has the same hole pattern, so could I use a socket 604 hole through tower cooler on my socket 423 will there be a pressure problem due to height differences?
Reply 1 of 13, by pentiumspeed
Does the case standoff lines up with your socket 423 holes? If not, and if the weight of the socket 604 heatsink is similar to consumer heat pipe heatsinks. Just figure out to mount 604 heatsink anyway.
Cheers,
Great Northern aka Canada.
Reply 2 of 13, by candle_86
Yes it does, Intel D850GB board and it seems Intel followed their guidelines exactly. I can get standoffs that fit or build a backplate like how and does.
The 694 coolers just seem better built and better designed that the stuff I find for 423 and it seems like they can keep it cooler.
Reply 3 of 13, by PC Hoarder Patrol
As 423, 603/604 and 771 all share the same hole spacings on the board it's usually possible to swap coolers within certain limits (the later 60x & 771 designs with intergated stand-offs can be a PITA to reuse). Although it makes for a more secure and flex-resistant fixing to screw- mount directly to the motherboard tray or to a separate backplate, it isn't absolutely necessary as some versions of the black retaining bars came with the same simple expanding push-thru pins some Slot 1 retention mechanisms used, like this one fot the MSI 850 Pro2
The attachment msi850pro2_socket.jpg is no longer available
Reply 4 of 13, by pentiumspeed
Learned something new! Thanks!
Try to get a fan controller so you can slow the fan on 604 heatsinks, they were made to spin insanely.
Cheers,
Reply 5 of 13, by candle_86
I like the idea of through hole mounting, seems like it would make it more stable and remove any stress on the board, and these 423 boards arnt real common on eBay not like 478 boards
Reply 6 of 13, by red-ray
I thought I had a Socket 604/603 cooler in my MSI MS-6385 Socket 423 system so I checked and I have. I must have installed this at least 10 years ago and it has always worked well.
file.php?id=82794
Reply 7 of 13, by Tetrium
Nice, I wasn't aware of this yet! Learned something new today, cheers 😀
Btw, I always assumed s771 used the same cooling solutions as s775, but mostly because I never bothered to dive into this due to me not having any motherboards using any of these sockets (except s423)
My retro rigs (old topic)
Report spammers here!
Reply 8 of 13, by red-ray
Tetrium wrote on 2020-05-14, 19:20:
I am not 100% sure about coolers and think they are that same, but know it's pretty easy to install an LGA771 CPU in an LGA775 socket!
file.php?id=83077
Reply 9 of 13, by darry
I can attest to the fact that a socket 771 CPU in a socket 775 board adapted to work with it (pin swap sticker, plastic guides filed off) works fine with a socket 775 cooler .
Reply 10 of 13, by red-ray
darry wrote on 2020-05-14, 22:19:
I filed notches into the LGA771 CPU as LGA771 CPUs are way cheaper than LGA775 motherboards
Reply 11 of 13, by darry
red-ray wrote on 2020-05-14, 22:41:
I thought of doing that, but filing plastic seemed easier than filing whatever the CPU is made of . Besides, a Xeon E5450 is probably the end of the road for that board (Asus P5K Deluxe Wifi AP) . Even if the socket 771 CPU ever does fail, a socket 775 CPU can still be installed; one just needs to be extra careful about orientation .
Reply 12 of 13, by PC Hoarder Patrol
As far as socket hole pitch goes, here's a couple of handy guides to refer to
The attachment socket holes 01.gif is no longer available
The attachment socket holes 02.png is no longer available
the bigger problems with cross-compatibility come because of either the aforementioned integrated stand-offs or because the relative vertical dimensions between the heatsink base and the IHS surface have changed between sockets, leading to either to too much / to little load or in some cases no contact at all between the two.
Reply 13 of 13, by candle_86
PC Hoarder Patrol wrote on 2020-05-14, 23:41:
As far as socket hole pitch goes, here's a couple of handy guides to refer to […]
Well the sinks I'm eyeballing screw into standard standoffs and are spring loaded
