First post, by perhenden
Hi,
I'm trying to get an old Compaq Armada 7770 laptop working. The hard drive and its caddy is missing. The caddy contains an adapter for connecting a 44-pin IDE drive.
I want to connect a hard drive to the machine.
How can I replace this adapter (or caddy)?
Pictures of the caddy is attached to this post. (Source: https://www.ebay.com/itm/Compaq-194086-001-Ha … rs/193383897406)
Notice how it is not as wide as 44-pin IDE.
    64.69 KiB
    43.01 KiB
    26.67 KiB
Reply 2 of 3, by pentiumspeed
This one you have, also LTE ELITE 4/xx series uses these same hard drive caddy. Checked by pulled one from my LTE ELITE 4/50E.
Cheers,
Great Northern aka Canada.
Reply 3 of 3, by perhenden
The LTE 5000 and 5300 also have this type of proprietary adapter for IDE 44-pin, and a similar, but not compatible caddy. I found those and can use them for spare parts 😀
Now I have good odds for getting two working machine out of the five models mentioned in the thread.
