First post, by LewisRaz
Hello all. I have this turbo lcd display that I want to set up.
The motherboard has a 3 pin turbo switch header and I have a switch on it and the turbo function itself works.
It also has a 2 pin turbo LED header.
I am guessing from looking at others that 2 pins will be for power. 2 will connect to the motherboard header and the final 2 will go to the turbo LED.
I do not own a multimeter to test however so was wondering if anyone had encountered one like this before?
It does not seem to be any from this list:
http://www.minuszerodegrees.net/led_speed_dis … eed_display.htm (This site appears to be down right now)
Forgive me is this is a simple question but I have not messed with one of these before and do not want to break it.
Cheers
    71.81 KiB
My retro pc youtube channel
Twitter
Reply 1 of 7, by PARKE
There are threads about these displays every couple of months but I cannot rember this one. It seems there are more different types out there than listed on the minuszerodegrees site.
Usually when there are 4 sets of connectors like as on top left in your sample then the connector with three pins (high-common-low) is meant to be connected to the turbo switch. For this type of setup the turbo switch has 2x3 sets of wires:
http://www.suntekpc.com/htm-2/power-switch-pu … urbo-3p3c-2.htm
The three connectors with 2 pins each are then meant for 5v power, turbo led on frontpanel, and power led on front panel.
Aren't there any markings next to these three connectors ?
Reply 3 of 7, by LewisRaz
Thanks for the replies. I have thrown together this extremely high tech diagram of what I can see.
I have a basic understanding of electronics but nothing like the brains on this forum! probably simple for some.
Seeing as I have positive and negative marked and 2 of the sets are joined that this I can narrow it down to 5050. Someone who understands these components better will probably think it is obvious now.
I am thinking it is the end 2 pins for power as they feed into the transistors and also some common rails across the bottom jumpers?
The bridged ones could be for 2pin LED input signal from motherboard and the turbo LED on the case? (another 2 pin).
This is the logic my brain is seeing.. I am happy to be corrected however!
EDIT: Just for clarity the red lines are traces, not jumpers.
    14.3 KiB
Twitter
Reply 4 of 7, by PARKE
LewisRaz wrote on 2020-05-22, 12:23:
I have a display with a similar set of 4 connectors (see photo) and in combination with a later 486 mobo only the 3-pin turbo switch connector (red-black-white) and the 2-pin 5volt connector (green-black) are needed because both the frontpanel power led + turbo led get their juice straight from the mobo.
111.67 KiB
Reply 5 of 7, by LewisRaz
I have it powered!
And after some investigating it became pretty easy to set up!
For anyone discovering this thread in the future. My diagram and assumptions were correct.
Twitter
Reply 7 of 7, by LewisRaz
Cheers. For reference J4 seemed to toggle a permanent display(turbo switch had no effect on it) or the other position where it would toggle with the switch.
The actual display segments were similar to this: http://www.minuszerodegrees.net/led_speed_dis … 20-%20S-501.jpg
Although the positions did not mean the same as that. It was not difficult to work out what each position did.
Twitter
