Instantiation COM error
First post, by Guest
I Once had VDMSound and It worked perfectly and for some reason one day it started to display this error message for everything and the Load with VDMsound option dissapeared from my Run With toolbar thing on XP. The error message plays that Error noise and then It says ERROR Instantiation could not load... and it does that for every feature that Vdmsound has it says could not load Wavedevice.dll Mididdevice.dll Etc. then after it does that about 10 times the program terminates unless you set it not to, in which case VDDloader.dll loads properly but all the rest of them don't. I tried a different version and then it had a problem with the PIF file. I corrected that and now I am getting this error message. VDMsound stopped working when I started to get adware on My computer ad Still, to this day I ant get it off. I've tried every program known to man Virus killeres popup blockers spyware zappers everything. Anyways I think that VDMsound not working is a result of me not bieng able to remove this crap from my computer. Does anyone have a solution. (The only reason I got VDMsound was to play the Wolfenstien 3D mod "End of Destiny" and It's just not "Good" without the music!!) Does anyone have a solution to this problem?
Reply 1 of 1, by Guest
I jut loaded VDMsound again and this time got something quite peculiar. I got LoadingVDDloader.dll
error encountered during post-initialization (0xf0).
VDMS loaded properly, but encountered an error while initializing.
Don't hesitate seek support on the VDMS site
Press any key to continue...
